2003 Honda Pilot - Engine Check Light Not Illuminating
2003 Pilot Engine Check Light Not Illuminating at start up or any time. Pulled ECU fuse to reset system. Pulled dashboard instrument cluster to change bulb but not sure if LEDs on circuit board are replaceable or not. Location of bulb is LED 181. Any help about fixing engine check light or how to remove and replace LED would be appreciated. Thanks.
2003 Honda Pilot Check Engine Light - ECM
Have a 2003 Pilot check engine light never will illuminate when starting or running. This is causing car to fail emission check. Scan Coder shows no errors. One opinion is that the ECM is bad or has a bad connection. Anyone have experience in this area? Where exact is the ECM located in the dash of this car and what do I need to remove from dash to check ECM? Thanks
