Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
Remove IMA?
Old 11-02-2010, 07:47 AM
cmdr430's Avatar
Default Remove IMA?
Is it possible to remove the IMA, and batteries to run the car as just a gas powered vehicle and not a hybrid?
If it is possible, I would assume this would drop quite a bit of weight from the car....
After that has been done, possibly a FIT turbo kit?
Just thinking out loud....
Any thoughts?
cmdr430 is offline
Old 11-02-2010, 08:02 AM
be professional
Targa250R's Avatar
Default Re: Remove IMA?
Possible? Certainly. Feasible? No. It would require a fair bit of custom work.
If you want to do something like that, your best bet would just be a complete engine/drivetrain swap.
Targa250R is offline
Old 11-02-2010, 08:59 AM
crx(gator)'s Avatar
why wouldnt you want IMA AND turbo?
crx(gator) is offline
Old 11-02-2010, 09:04 AM
The engine is designed to operate without the battery pack but you won't get very far without the motor and the 12volt converter. The motor is a very small pancake motor and the battery pack is a stack of D cells in the back. I'd bet the total weight for the IMA is about the same as the seats.
The exact weights for the entire setup are probably posted somewhere online. Some of the Insight guys have no doubt taken everything out and weighed everything. I believe there was a guy on Ecomodder looking to remove the whole IMA setup but you would be better off looking for a step by step guide to removing the IMA on the Insight board before even considering this. Good luck.
Allch Chcar is offline
Old 11-04-2010, 01:24 AM
JonnyCoupe's Avatar
The weight for pretty much everything on the IMA system on the Insight Mk2 is 56kg. The CRZ is gonna be the same, if not a little lower due to shorter 3 phase cables.
Source : A2mac1 Auto Reverse.
I basically can see the whole car stripped down into each part with photos and the weight of each one.
JonnyCoupe is offline
Old 11-04-2010, 03:43 AM
civicflow's Avatar
Plus the IMA acts as the starter and alternator for the CRZ, I wouldn't see any reason to remove it. Also your brakes last alot longer with the IMA since it does most of the braking to recharge the battery.
civicflow is offline
Old 11-04-2010, 08:59 AM
Bwill9886's Avatar
Considering what Bisimoto just did with their CR-Z, I don't think there is any reason to drop the IMA for a turbo setup.
Sounds like it would mostly cause more problems than it would ever solve.
Bwill9886 is offline
Old 11-04-2010, 11:58 PM
00falcon's Avatar
interesting... only 56kg eh
anyone know what bisimoto did to beef up the tranny?
00falcon is offline
Old 11-05-2010, 07:35 PM
liquor assassin's Avatar
if you are going to remove anything just remove the whole motor and stuff a k in there
liquor assassin is offline
Old 11-05-2010, 07:40 PM
dont even know id that would be possible but being able to put a k in one of those is going to be on the minds of alot of people
elliascool
04-02-2011 11:36 PM
89MA70
Acura TSX
03-26-2010 09:03 PM
LLCjr
02-02-2009 08:36 PM
chubbyfire
05-25-2005 11:46 PM
Quick Reply: Remove IMA?
  • Ask a Question
Question Title:
Description:
