Real curb weight, engineless.
Official specs from Honda.com and dealer stickers are claiming as follows:
Curb Weight (lbs) Base Model Manual: 2637 Base Model Auto: 2690 EX Model Manual: 2650 EX Model Auto: 2703 And the navigation adds 4 lbs to any weight. Spoon is claiming to have shed 220lbs off the car's weight in their $8,000 "package", which would theoretically yield: Base Model: 2417 lbs EX Model: 2430 lbs However, they also have NOT removed the hybrid components. This is what I am most curious about. Anyone else in a shop who has one of these and a scale have any numbers to share? Looking for some real numbers, speculations I can make on my own. Thanks! Citation for the Spoon claim from Road and Track: http://www.roadandtrack.com/tests/ca...on-sports-cr-z |
Re: Real curb weight, engineless.
100V system in the insight, CR-Z and will be Jazz = IMA is 56kg all in, inveter, motor, battery, cables.
Originally Posted by JonnyCoupe
(Post 44262082)
As soon as I get my scales back I'm going to weigh the KR-Z to get an idea.I will post the results.
Bisi said complete IMA in CRZ was 79lbs.
Originally Posted by CRVRX
(Post 44268025)
Originally Posted by get RIGHT
(Post 44271336)
My source is the A2mac1 autoreverse system where every single part of a car is disassembled, photographed and weighed.
79lbs doesnt cover everything you can remove when removing IMA. |
(Post 44268025)
sounds interesting i want to see the numbers
In for numbers.
I would bet it's around 100Lbs. all in all. those electric comps. arn't light
Still holding out for a confirmation on this.
TIA |
bump in for this
bump in for this
Mission Motors full IMA system including Battery + 12V output is 27Kg
Stock 16 inch wheel + tire is 15.5 Kg short stock nuts 32 g (verified) I ordered : OZ Allegeritta 17 inch + tire Conti Sport contact 3 i hope to have total weight wheel + tire under 14.6 kg. I use aluminium 2024 alliage RAYS weight 23g Rear seat + Back total weight is 8.7 Kg (easy to remove 3 nuts) however this looks ugly w/o rear seats, i would like to have the US spec parts that fits in the rear seats place. ==> contact me. (i hope those parts are lighter) Manual of the CR-Z in french indicate a weight of the rear battery pack NiMh of approx 100kg, however this is in the text to explain car balance, and not in a spec sheet. |
The whole IMA system with battery and motor and everything is less than 100lbs?
That's a pretty fantastic hp/lb yield. |
Originally Posted by alollini
(Post 44451188)
