Gen 1 Honda Insight Ground Control coilovers
Just in case anyone out there wants to get a better suspension setup for their Gen 1 Honda Insight, your wait might soon be over. Currently in the prototype phase and under going testing on my Insight...
http://i285.photobucket.com/albums/l...rprototype.jpg http://i285.photobucket.com/albums/l...tprototype.jpg |
Re: Gen 1 Honda Insight Ground Control coilovers
:thumbup:
Any estimated time for release? |
Time of release is dependent upon aftermarket dampers/shocks and overall interest. The rear shocks of the Insight will be troublesome to reproduce due to size and weird mounting.
Hello,
how`s things at the moment? Is there a solution to the suspension of the ZE1? regards |
Anyone rolling around on a ground control setup yet? I know i'm somewhat reviving a dead thread but i'm interested in seeing what options may soon be available for us gen1 owners.
I've had the GC's on my insight since i posted the prototype pics and i have replaced the rear shock with some from Monroe.
As for ride comfort, they are definitely much stiffer than stock but improve handling greatly in my opinion. No more "floaty" suspension feel at speed and door handle scraping cornering. These are available on GC's website for all Gen 1 Insights. If you want more info for Gen 1's in general, check out www.insightcentral.net |
Is it true people use caddy shocks as a replacement for the rears?
do you have finished pictures on the car?
Originally Posted by dkim48
(Post 48191018)
Originally Posted by tkocrx
(Post 48197889)
Here she is lowered on my old Mugen RNR's. I only lowered here half an inch.
http://i285.photobucket.com/albums/l...ps9b2a8270.jpg http://i285.photobucket.com/albums/l...psd2a906c1.jpg |
good info. Thanks for sharing.
Originally Posted by Blue-Civic-Hybrid
(Post 48208830)
No, the Monroe shocks I used are from a 1995 Chevy Cavalier.
Put the new pics up!
are these on the market now?
Yes they are on the Ground Control website...
Ground control makes awesome coilovers. We've used them on our past track cars and they handled amazing!
How many company's make coilover kits for the Insight besides GC and Tanabe? Seems like an older chassis but doesn't it work with the CR-Z as well?
I'm curious when you go lower with the Insight what type of camber kit do you use?
Originally Posted by vtecn8ive
(Post 49140721)
(Post 49140721)
http://www.andysautosport.com/honda/...shims/ingalls/ http://www.andysautosport.com/images...660-series.jpg |
TunerNoob, thanks for the info, I didn't know about those shims for the rears. I don't think I will use them since my alignment seems to be none the worse.
Here is my Insight lowered on GC's and custom rear shocks from GAZ shocks in the UK. http://i285.photobucket.com/albums/l...ps81153355.jpg http://i285.photobucket.com/albums/l...ps9b0fadf8.jpg http://i285.photobucket.com/albums/l...psac2857cf.jpg |
(Post 49152701)
Also, now that you have a more performance oriented ride height and (assuming) spring rates, you probably want a more performance oriented alignment. Shim the rear to 0° toe instead of the factory specified toe in and the car will feel much more responsive. |
Originally Posted by TunerN00b
(Post 49154147)
I hope you got it aligned anyway. If the car had any negative camber stock in the rear, it will now have additional toe in due to the change in angle of the twist beam.
Do you have more info on the GAZ struts?
