Electric AC Compressors: true?
I am building a K20 coninversion in a Fiat X1/9 for a customer who has to retain AC. Do the hybrid vehicles have electric compressors? If so, where might I go to try to buy one?
Re: Electric AC Compressors: true?
oh damn I have no idea about that but please post the build.
I think all the new hybrids use an electric ac compressor. They are primarily belt drivin, but when motor is at idle stop it uses an electric motor to keep it turning. Honda has them but they are not cheap. Good luck with this build, I want more info and pictures!
i found this write up on that swap into a fiat.
http://www.midwest-x19.com/FiatX19Acura_files/frame.htm |
Originally Posted by Longitudinal
(Post 45060719)
Originally Posted by dem0nk1d
(Post 45062474)
http://www.midwest-x19.com/FiatX19Acura_files/frame.htm Absolutely positively cannot use the K20 compressor or the Fiat unit--NO space for them. If I have to go engine-driven, I have to find something teeny-tiny (about the size of an alternator) to mount in a non-factory location. The K20 compressor would have to occupy the space of the leading pick-up point for the right rear control arm--can't do without that! I'll try to put up some pics of the project. :) |
Then I would find your Cooling Depot, [Four Seasons] retailer in your area... http://www.4s.com/ROOT-Home1/Content.aspx and ask them for the smallest compressor they have. 94
Here is an idea. Snag a compressor and an electric motor. Fab a pulley and just drive the belt with the motor.
didn't some of the really tiny cars such as the geo metro have really small compressors?
your going to need a compressor that is sized to pump the proper amount of refrigerant through the evap and condensor, just throwing in any compressor my not work properly. compressors and the other a/c componets are sized in accordance to the space size and load of what your trying to cool.
Originally Posted by adamrich33
(Post 45080509)
OP, you may want to look at Panasonic compressors, they make some pretty small compressors. 94 |
