Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
Offical k20/k24 swaped insights
Old 03-11-2017, 04:58 PM
  #151
SpoolinAWD's Avatar
Default Re: Offical k20/k24 swaped insights
I am understanding this more. I have an 01 as well and the manual I have is 00.
Old 03-12-2017, 10:37 AM
  #152
Ryanthegreat1's Avatar
Looks like the rear skirts are going to need some heating and bending to clear the tires. Have to wait for a warm day to get enough heat into them for a nice gradual bend.
Old 03-12-2017, 11:18 AM
  #153
BongoBennie's Avatar
How much bow/bulge do you think you need? Thnx for R&D btw
Old 03-13-2017, 06:11 AM
  #154
I don't think it will require much to get the needed clearance.
I was thinking stacking up 3-4 layer of cardboard over the tire in that area and then installing the skirt. Then heating the whole skirt to get a very gentle curve over the whole panel.
Old 03-14-2017, 10:18 AM
  #155
SpoolinAWD's Avatar
I am thinking of running the e7 mrly directly to the main relay to ground it. Our main rellay is grounded all the time and switched power as you said so will this allow the ecm to switch the relay?
Do you have any notes or a diagram how you wired yours Ryan?
Old 03-14-2017, 04:42 PM
  #156
You are on the right track.
Correct the 00-04 main relay control is wired to ground and then the ignition switch supplies the +12v to turn on the relay. Just pull the ground off the relay and running it to the ECM won't work as the ignition switch still cuts the +12v side.
The correct way would be to wire it like an 05-06 Insight. +12v constant on one side of the main relay control and the other side goes to the ECM for ground.
I thought about adding a relay just to power the ECM but that also won't work because the EVAP stuff also needs to remained powered for the leak test that is run with the engine off and the ECM still powered.
Old 03-17-2017, 10:07 AM
  #157
Two tanks at 30mpg each. Not great but also don't have the ECM memory fixed or the rear skirts installed.
Old 03-17-2017, 11:08 AM
  #158
SpoolinAWD's Avatar
Old 03-17-2017, 11:11 AM
  #159
Duh! I did not even think about pulling from the +12 side of the main relay for the control side.
That looks right. Let me dig up my notes and see where I sent the main relay output.
Old 03-17-2017, 11:23 AM
  #160
SpoolinAWD's Avatar
I have been researching the wiring for a few days now. I hope this is accurate and helps someone else. I have not made any connections yet, still trying to decide if this will work.
Old 03-17-2017, 11:25 AM
  #161
I will find my notes and compare.
On the main relay I would disconnect the +12 control side from the ignition switch after jumping to the +12 supply side.
Old 03-18-2017, 11:11 AM
  #162
SpoolinAWD's Avatar
my 01 cvt wiring is different than the 00 esm that I have been reading. Back to square one.
Old 03-18-2017, 11:14 AM
  #163
My 00-06 ETM shows that early 01's were different from late 01's in some areas. The CVTs were also very different from the MTs. What do you need? I can snap a couple pictures and post them up.
Old 03-18-2017, 11:37 AM
  #164
SpoolinAWD's Avatar
Start with the ecm wiring. A, B, and C connectors. I really appreciate it, getting frustrated.
Old 03-18-2017, 11:53 AM
  #165
Here is the 00-06 Insight ECM wiring.
Old 03-18-2017, 12:33 PM
  #166
SpoolinAWD's Avatar
Thanks Ryan
Old 03-18-2017, 12:42 PM
  #167
Honda99SiR's Avatar
Originally Posted by SpoolinAWD
extremely helpful great diagram
Old 03-19-2017, 07:59 AM
  #168
Oh the sun is out! Lets see about making skirts fit and fixing the main relay issue.
Old 03-19-2017, 02:49 PM
  #169
SpoolinAWD's Avatar
I was reading the connector backwards, most of the wires I have written out do coincide with what is on my car. Still playing with the wiring but the car does crank!
Old 03-19-2017, 04:15 PM
  #170
Heh, you are not the first to read the connectors backwards!
Got my skirts to fit. Installed them and then shoved two sheets of cardboard between the tire and skirt and let the space heater blow on it for 15-20 minutes to soften up the ABS. Worked mint!
Old 03-19-2017, 05:36 PM
  #171
SpoolinAWD's Avatar
Did you take a look at the main relay? It shares a ground through the connector with another relay they i have not been able to identify.
Old 03-19-2017, 05:47 PM
  #172
That second relay is the A/T Reverse relay according to picture 51 in my manual, page 201-8.
I did not get a chance to look at mine. Had to do domestic stuffs.
Old 03-19-2017, 06:04 PM
  #173
SpoolinAWD's Avatar
Old 03-19-2017, 06:14 PM
  #174
Nice. I guess I really have no excuse.
Did I mention how retarded fast a turbo K series in an Insight is going to be?
Old 03-24-2017, 04:19 PM
  #175
SpoolinAWD's Avatar
Quick Reply: Offical k20/k24 swaped insights
