Rear toe ajdustment for Fits?
I spent a fortune to have my '97 Civic lowered properly, an act seeminly lacking in the aftermarket tuning community.
After the Tein springs and dampers went in, they were quickly followed by front and rear camber kits and a rear toe-adjustment kit. After a bit of hassle with alignments, all four wheels on my car point straight and the tires are in full contact with the ground.
I want to do the same when I purchase the '09 Fit.
I've managed to find front and rear camber kits for the current Fit, but not toe-adjustment kits. Do these exist? Do you Fit owners experience problems with rear toe?
they should have stock toe adjustments in the rear...dont worry about it..
btw 97 civics have stock rear toe adjustment as well so idk why your purchased a toe adjustment kit...i didnt even know they made those lol
Re: (high_revs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high_revs »</TD></TR><TR><TD CLASS="quote">they should have stock toe adjustments in the rear...dont worry about it..
btw 97 civics have stock rear toe adjustment as well so idk why your purchased a toe adjustment kit...i didnt even know they made those lol</TD></TR></TABLE>
Fit's and Civics have totally different suspension.
Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">
Fit's and Civics have totally different suspension.</TD></TR></TABLE>
umm duhh...every honda has front and rear toe adjustments from factory tho. no need for aftermarket toes adjusting components.
Re: (high_revs)
umm duhh...every honda has front and rear toe adjustments from factory tho. no need for aftermarket toes adjusting components.</TD></TR></TABLE>
07-08 Fits DO NOT have rear toe adjustment. And just looking at the car you can see the weird toe on the rear of the Fit.
I wouldnt worry about rear toe. Im sure its non adjustable for a reason. Like the factory rear camber. If it was zeroed out I bet the Fit would handle horrible.
And even slamming a Fit camber bolts arent needed.
I added negative camber up front to reduce rubbing on my old wheels. Im at around -1.5 camber up front and my tires are showing no sign of camber ware.
your right they dont..i'ved only done one alignment on one fit...but like you said, i wouldnt really worry about toe...wont be too off anyways unless if you have something bent.
Re: (high_revs)
umm duhh...every honda has front and rear toe adjustments from factory tho.</TD></TR></TABLE>
umm duhh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mx6GT89 »</TD></TR><TR><TD CLASS="quote">
07-08 Fits DO NOT have rear toe adjustment.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high_revs »</TD></TR><TR><TD CLASS="quote">your right they dont..</TD></TR></TABLE>
umm duhh
i recently hammered my fit and tok it to get the alignment. i thought since the rear is not adjustable it would be really close to stock...wrong! its off pretty bad and for some reason my front driver side is 1.5° and my passenger side is 0° on the camber. im thinkin about that spc kit that has adjustable camber bolts for the front and adjustable shims for the rear.
MrCivic98
Suspension & Brakes
10-31-2005 07:25 AM
EK k kay
Suspension & Brakes
05-17-2005 09:39 AM
