vtec solenoid wiring
where can I locate a wiring schematic for the ecu, specifically the vtec solenoid/ switch? Getting code p1259 even after replacing the unit, did voltage checks and ohms resistance. with the engine off, key on, I can clear the code with my scanner, it acknowledges codes are cleared and immediately recheck codes and its set again without the engine even running. Im thinking its possibly the computer itself but I want to verify the wires first.
Ferio Wdm Edition
Re: vtec solenoid wiring
Sounds like limp mode, the colors of the vtec solenoid SHOULD be the same at each end. I cant seem to find a good schematic for you, but swap out ecu with a known good one.. I dont think vtec solenoid can put the car in limp mode.. Is there any stored codes?
Dahhhbeed
14
08-27-2016 03:08 PM
infamousALLMTR
05-20-2002 04:10 PM
