Honda CR-V & Element 2WD & 4WD Element & CR-V
Struts/Ball Joints
Old 11-05-2012, 10:42 AM
teamo's Avatar
Default Struts/Ball Joints
02 CRV EX. I am going to replace all four struts as well as the front lower ball joints. I think I have a good handle on doing it myself. All things being equal should I go with Monroe, KYB, or Gabriel struts? Should I also do the lower control arm bushings while I have it all apart? What size is the front axle nut? I have seen three different sizes while shopping for parts.
Old 11-05-2012, 11:03 AM
teamo's Avatar
Default Re: Struts/Ball Joints
I was thinking of pressing the ball joints into the knuckles with one of those rented c clamp type from the auto parts store. I did see a couple of cheap presses at Harbor Freight Tools. One of them was a 20 ton and the other one was a 12 ton. Is the 12 ton press enough to do the ball joints and any other bushings that I might have to press or shoud I step it up to the 20 ton model?
Old 11-07-2012, 05:45 PM
Seagull Management
94EG8's Avatar
If you aren't buying OEM shocks buy KYB.
Old 11-07-2012, 06:00 PM
LDForget's Avatar
i run KYB's on my slammed CRV and it rides amazing.
Kevs02Accord
11-08-2011 04:04 AM
MrViet
01-11-2010 06:14 PM
89efhatchcrap
Suspension & Brakes
24
02-17-2009 10:36 AM
Cabby89
07-31-2007 08:06 PM
GruvyTune
08-10-2004 11:30 PM
Quick Reply: Struts/Ball Joints
