Replacing the interior clock?
The clock in my Cr-V from 1998 does not work anymore and it would be nice to replace it with one that shows the outside temperature. The original clock is the 4-wire type and the one I would like to install has 7-wires and the outside sensor has two wires.
It's easy to install the 4 wires needed for the clock but how do I connect the sensor to the clock? I guess I have to connect some kind of 5V referens to the sensor? Since I do not have a car with AC.
The clock itself seems to be a direct fit in the upper center vent. console -at least they look a like.
Re: Replacing the interior clock?
Sounds like you have the JDM clock with temp. You'll need to wire the temp gauge somewhere outside the cabin and then feed it to the clock.
Berz out.
Berz out.
Yes I´m thinking to replace it with a JDM clock, placing the sensor outside is not a big issue it´s more the wiring, I guess I can not wire it directly to the clock since it needs a 5 volt reference and I do not have a clue on how to connect it all.
If you want to keep your factory clock, try this..........it worked for me.
Honda CR-V 1999-2001 Clock Fix | Jason's Blog
KiwiRuss
Honda CR-V & Element
04-01-2022 12:43 PM
bopbop93030
Audio / Security / Video
08-14-2009 06:15 AM
