Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 CRV Shuts off driving wont turn on..
Old 01-26-2017, 02:03 AM
MILKYWEY's Avatar
Default 1998 CRV Shuts off driving wont turn on..
1998 CRV shuts off driving to work and didn't turn back on. before the engine completely died, I step on the gas pedal RPM didn't shoot up. I tried turn back on nothing happened, engine didn't try fire up BUT I did feel it turn over.. it felt like I ran out of gas but I didn't.. I'm thinking it could be either fuel injectors or fuel pump.. I haven't pop the hood yet and try troubleshoot..
.PLEASE HELP...
Old 01-26-2017, 05:28 AM
sf340b's Avatar
Default Re: 1998 CRV Shuts off driving wont turn on..
Pull the distributor cap off and see if the rotor turns as you turn the engine over.
Old 01-28-2017, 12:53 AM
MILKYWEY's Avatar
found the problem it was the ignition coil went out so I replace hole thing... $260.00 repair
Old 01-28-2017, 11:22 AM
sf340b's Avatar
OOOh. That hurts. I had the same thing a while back but may have got off a little cheaper including the tow home.
Old 01-29-2017, 10:06 AM
M-benz's Avatar
Out of curiosity , can we just replace the ignition coil by itself ? If so, what is best one out there beside OEM one ?
Old 01-30-2017, 12:58 PM
sf340b's Avatar
It has been a while and I do not remember exactly what I did.
CRV stopped running, would not start.
No Fire.
Troubleshooting and I replaced the ICM in the distributor.
Lost ability to TS I guess as that did not work and replaced coil also.
CRV runs fine.
All parts were Oreilly specials as CRV is stock.
Old 02-10-2017, 09:27 AM
Alpha_tech's Avatar
Glad it was just the ignition coil.
The cap and rotor on my older CRV had to change the whole cap and rotor and ignition coil.
Old 02-10-2017, 12:30 PM
UK-Kev's Avatar
For anybody else reading this blog, please see the link below on how to diagnose correctly.
Part 1 -How to Test the Igniter, Ignition Coil Accord, Civic, CRV, and Odyssey
Regards,
Kev
Bobn4aples
04-27-2017 04:19 AM
Run Away
18
12-30-2006 06:40 AM
cbp_crx
11-26-2004 10:06 AM
Quick Reply: 1998 CRV Shuts off driving wont turn on..
