Honda CR-V & Element 2WD & 4WD Element & CR-V
heater not working.... what can it be?
Old 11-24-2010, 11:40 PM
SPOON_BeIgHtEeNsEe's Avatar
Default heater not working.... what can it be?
well winter is HERE (DAMMIT!!!!!!!!) and its SUPER cold... my damn heater isnt working... i flushed the coolant and still doesnt work... i even shoved the garden hose into the coolant lines (line that goes to the heater core box, two lines on the firewall) and it returned fine so i dont think its clogged... it does turn on but blows nothing but COLD AIR!!!! what can it be? i need heat in the crv because the odyssey isnt cutting it in the snow tho it does have heat
Old 11-25-2010, 02:13 PM
Boosted Power's Avatar
Default Re: heater not working.... what can it be?
How is the temperature gauge? High, good, low? (thermostat, radiator cap?)
Check the heater valve. Make sure it's opening up all the way to let coolant flow. Or yet, if it even moves at all when your moving the hot/cold slider.
Old 11-25-2010, 06:33 PM
engine temp is fine half way.... radiator is brand new tehermostat i havent checked.... but car doesnt over heat so i think its ok??? when i flushed the coolant i checked that valve and it was clean... i also had my brother turn it from hot to cold, it opened and closed fine...
Old 11-27-2010, 11:22 AM
NO ONE?
Old 11-29-2010, 02:43 PM
majones24's Avatar
Did you check the fuses. I am also having a problem with my heater. The heater works but the blower wont blow the air.
Old 11-30-2010, 01:54 PM
it was the damn heater core.... damn was it a bitch to get that dash out... but it works so thats all that matter right now cause snow is pouring like crazy....
grimview
07-22-2013 03:32 PM
Hitmo
11-23-2011 06:32 AM
Circaskaterr
02-01-2010 10:59 PM
x92preludesix
04-08-2007 05:21 AM
simplypinoyy
23
08-06-2004 03:06 PM
Quick Reply: heater not working.... what can it be?
