99 Manual Trans Swap. Electrical issues,
Well I have a 99 Crv that had factory auto everything and now has the 5 speed in it. But after messing with it , I can't get it to turn over using key switch. This has become a bit of a nightmare.
There was another thread on here that mentioned using and auto harness and need to bypass the NSS and trick the clutch safety switch. The original author has not been on since 2013 and will not be able to contact obviously.
Any more info would help. Or a push in the right direction.
Also the key will not come out of ignition while under power.
Thanks in advanced for your help
Re: 99 Manual Trans Swap. Electrical issues,
Did you follow a guide? See if this guy did something you didn't. https://honda-tech.com/honda-element...rsion-3068556/
streetelementcc
10-08-2011 09:19 PM
datnigabluberry
03-13-2006 10:00 AM
bouttobeout
03-12-2004 02:36 PM
