Honda CR-V & Element 2WD & 4WD Element & CR-V
99 CRV - Sputtering / Hesitation under acceleration
Old 11-21-2011, 09:51 PM
Nothing.Special's Avatar
Default 99 CRV - Sputtering / Hesitation under acceleration
So this doesn't happen all the time but it happens every now and then, when under acceleration, sometimes it will hesitate and sputter.
Possible causes? Easy fix? What should I look at first?
Thanks for the help H-T.
Old 11-22-2011, 05:58 AM
57explorer's Avatar
Default Re: 99 CRV - Sputtering / Hesitation under acceleration
i would start off by putting in new spark plugs in. NGK seem to work the best for me. Thats usually the best place to start
Old 11-26-2011, 08:20 PM
el crapitan's Avatar
check codes first. always
Old 12-04-2011, 07:26 PM
andrew4g63's Avatar
I would say spark plugs and wires would be a good choice.
Get ngk plugs and wires.
Not to much else is going to cause hesitation.
Old 12-05-2011, 10:27 PM
aside from the distributor and all of its internal components. any number of fuel related problems. ckp. ect sensor. vacuum leak(s). etc. etc..
yea. i'd say there's a whole helluva lot more than just plugs and wires to suspect.
codes are free to check. and they point you in the direction you need to go.
utilize the system the manufacturer has so graciously put in place
delsolo95
06-13-2011 06:15 AM
micah13x
11
04-14-2011 03:09 PM
hondaowner
04-06-2004 04:42 AM
SSBlueDC2
02-07-2003 07:45 PM
Quick Reply: 99 CRV - Sputtering / Hesitation under acceleration
