99 CRV - Oil Pan Gasket leaks
I have a 99 CRV the oil pan gasket has been replaced approx. 6 times in the past yr 1/2. The gasket has been torqued to spec both installed with sealant and also installed dry. Every time that there is a leak the leak seems to be from a different location. The oil pan has been checked for warped flange It has checked to be okay. Anyone have any suggestions on how to correct this issue.
Please Note: the tabs that should have the sealant have been coated with a small layer of sealant every time.
Any suggestions regarding this issue is highly appreciated! Thank you!
Re: 99 CRV - Oil Pan Gasket leaks
Whenever I repace and oil pan gasket I scrap as much of the old gasket off with a blade as I can then use a stiff brush and degreaser to remove any left over gasket material. I also had a good friend show me a trick that seems to work. set the lip of the oil pan on the edge of a work bench right side up (like it looks when mounted on the car) and take the round end of a ball peen hammer and center it over the mounting holes and take another hammer and gently hit the ballpeen, this helps flaten the mounting holes because sometimes they get a little dimpled when bolts are torqued. Dont go crazy on it just enough to knock down any protrusion that might create a leak in the gasket once tightened. And I spread a thin layer of sealent all the way around to help hold gasket in place while mounting and add protctive barrier against leaks.
Hope this helps
Hope this helps
I've tossed a few oil pans in my life soley based on how much **** was baked on the lip. I knew I wouldn't achieve a nice seal based on the imperfections. Sounds like you might have peace of mind if you spend a couple extra bucks and get a brand new oil pan.
