2008 crv bottom torque strut
Hi everyone, need help on figuring out the issue with the torque strut bottom passenger side of the crv. I bought this car used with bottom torque strut broken. I decided to replace all the mounts, engine mount passenger side and transmission mount also bottom and top torque struts. All the parts ordered through rock auto. Well after replacing all the mounts the wife drove, for 4 days when she started getting shaking when brakes are applied. I found out same torque strut is broken. Through warranty getting mount replaced, if it breaks again planning buying oem.
Question is, is there more mounts that i am missing?
Or should I be looking in other areas?
Re: 2008 crv bottom torque strut
If it shakes or vibrates when braking, it's definitely brakes related. Check those rotors. Although I'm sure having a broken mount doesn't help with vibration. I have no idea what kind of mounts are on an '08, but are the vibrations your reason for replacing all these mounts?
2wheelhunter
07-09-2006 03:57 PM
