Honda CR-V & Element 2WD & 4WD Element & CR-V
2007 CRV Rear Wiper Motor Woes
Old 11-30-2015, 08:52 AM
JimmyAtlantis's Avatar
Default 2007 CRV Rear Wiper Motor Woes
My wife's CRV's rear wiper motor decided to short out apparently blowing the fuse. I replaced it with a refurb part and the fuse doesn't blow anymore, but the motor won't turn off. Bad replacement part?
Old 11-30-2015, 06:20 PM
Global Moderator
tech8's Avatar
Default Re: 2007 CRV Rear Wiper Motor Woes
The symptoms (i.e., blown fuse previously, now running all the time) indicate a short in the (+) power wire (for example: another power wire touching the power wire to the rear wiper motor).
Old 12-01-2015, 03:32 AM
So why wouldn't the fuse just keep blowing instead with the new motor? The old motor was definitely dead. After originally replacing the fuse the motor would only make a couple very slow sweeps before blowing the fuse. I have another motor to try, but if this doesn't work where do I start tracking this down in the wiring?
Old 12-03-2015, 10:04 AM
Nobody knows? I know I'm not the only one who's had this problem since the part is out of stock pretty much everywhere.
Old 12-06-2015, 05:03 AM
Turned out to be a bad replacement part. Thanks for all the help. This place was hell of a lot more helpful 10 years ago.
James Blair
Honda Civic (2006 - 2015)
03-17-2013 05:04 AM
hatchy69
10-20-2011 10:31 AM
ascarberry
04-06-2011 01:07 PM
HondaS2000
09-26-2008 01:31 PM
drcalman
09-03-2004 11:27 AM
Quick Reply: 2007 CRV Rear Wiper Motor Woes
