Honda CR-V & Element 2WD & 4WD Element & CR-V
2007 CR-V Alarm won't turn off
Old 04-11-2017, 04:19 PM
nrh24's Avatar
Default 2007 CR-V Alarm won't turn off
Anyone have any ideas on how to turn off the alarm? I have the battery disconnected right now. I am unable to put the key in the door and turn because the lock cylinder is busted and that's how I got in this situation in the first place. (I had AAA open my door and I was planning on re programming some key fobs in order to unlock/lock my door as a temporary solution.) I've already tried turning the car on which does not stop the alarm. Thanks everyone!
Old 05-14-2017, 09:15 PM
Hamster65's Avatar
Default Re: 2007 CR-V Alarm won't turn off
Look for an orange wire behind your interior fuse box. Use a jumper wire or something similar to ground that wire. This will disarm it (same effect as turning the door lock to the unlock position with they key). As long as you keep that wire grounded, the alarm will be unable to re-arm.
djbrandonr
Audio / Security / Video
11-19-2006 04:59 PM
konidude
10-17-2006 09:11 AM
djbrandonr
07-22-2006 01:25 PM
alarmguy
01-07-2006 09:08 AM
willyboyK20
04-18-2002 04:51 AM
Quick Reply: 2007 CR-V Alarm won't turn off
