*Official H/T OFFROAD/LIFTED CR-V thread!*
#2251
Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
So it finally happened, blew the clutch out of my crv. Luckily got me all the way to work and ended up losing the clutch pedal and dying as i pulled into a parking spot. Have the parts on order; new flywheel clutch set and ended up ordering new t-stat, timing belt waterpump and a rear mail seal figure id pull the whole thing and take care of them all at once.
Just curious on any issues i should be aware of ahead of time. Ive pulled the d series out of my 96 coupe and put in a built one but that was a few years ago and never ran into any big issues with that one. Also if you guys have any other suggestion on maintenance items that I should look into replacing it would be greatly appreciated.
thanks all
thanks all
#2252
-Intl Steve Krew
Might want to change the front main seal VC gasket and oil pan gasket if you're going to pull the motor out.
#2253
derp resistant
to you guys with first gens running 215/75/15 tires, will the larger tire fit on the spare wheel? or will the cutout in the bumper get in the way?
#2254
Hello all! i just bought a 2006 CRV LX auto and I am looking to achieve this look, I read that these tires are 235/75/16 with 16x8 0 offset rims. I'm debating on buying the CMR 2" lift spacers.
I've read though a lot of this and will be reading all of it over the next few weeks. I don't plan to do much off road riding, This is my daily and plan to do some camping with it. Also I'm looking to add the fog lights to mine. Has anyone used the ebay OE replacement fog lights and is the installation easy?
#2255
I forgot I do actually have a oil pan gasket on the way, and I had changed the VC gasket when i did the cam seal a couple weeks ago but will look into the gasket set I order it might come with the front seal already was just labled as crankshaft seal kit. Thanks for the feed back!
#2256
#2258
#2259
#2260
#2261
What's up guys and girls! Just picked up a super clean *** 1999 CR-V EX AWD MANUAL with only 90k for $2000! Bought it off from a neighbor who's moving out, want to lift the beast with some OME springs, can someone give me the correct part number to the OME springs or direct me to a legit website for the parts.
Thanks!!!
btw will OEM shocks work will with the OME's or should I upgrade to like bilsteins 4600?
Thanks!!!
#2262
rocky road sells OME stuff, it's like they're horny for it. but I don't know if they have the best prices, you'd have to use google for that
#2264
#2265
Hey Gene, finally got around to purchasing the eBay crossbars. Did you have any issues with the bars whistling? I'm getting a really annoying whistle from them. If I open the slide the sunroof up it stops the whistle at about 60mph.
I'm thinking I either need to add either a fairing, or a rack to buffer the wind noise.
I was also thinking of maybe a DIY solution to use some pipe insulation and zip ties to give disrupt the airflow a bit and see if that helps.
#2266
Some recent pics (I'm jealous of the clear coat on your vehicles!):
Something to keep in mind if you guys are running more power - lights, stereos, whatever - I have a DC power and engineering alternator, and it kept stripping bolt holes or busting bolts in the bracket because the larger housing required standoffs which change the torque angles of the belt. Replacing the bracket and hardware worked for about 4K miles at a time, then it was a breakdown/overheat and tow.
This is the current fix:
Have any of you built or ordered brackets for a light bar above the windshield? I'm not 100% opposed to putting rivets or studs in the actual roof, but a bracket that attaches to the door sill seems a lot safer to me. They make vehicle specific mounts, of course, but the CR-V isn't on their list.
#2268
-Intl Steve Krew
I was going to purchase some Thule surfboard cushions, but this diy was $10 vs $50 lol.
Still looking for a decent rack. I want a slim aluminium rack but I can't find one that I like. It's all mostly for looks anyways.
#2269
-Intl Steve Krew
Also, I purchased a trailer for kayaks, dump runs, dirt bike hauling, camping, JDM cool points, etc.
It's not too shabby for $259!
I just need to wire it, get it registered, build some side walls (still debating on AL sidewalls or just go with plain Jane wood) and also need to build in a floor and start figuring out all the attachments for the above statement.
#2270
Hello guys,
I have a CR-V 1998 and i want to do some upgrades on him.
My fisrt question: which is the max tire size that i can put with the Old Man Emu Springs and the rest original without rubbing.
The 225/75/r15 fit well with the springs i mentioned?
Hope to see some opinions/ configs that you have
#2271
Hello guys,
#2273
Yeah the 235's are out of equation for me for that reason...
My ideia is to put the new springs to lift a bit and if you guys, say that the 225 fit well i think i go this way.
#2274
just got a 2005 silver crv, put a roof rack on and thats it. I'm about to put a k&n cold air intake in. what else should i do to it and start with
