ZC recommended oil
I put 20w50 in my dohc ZC motor to help stop some of the blowby I was getting. Is this alittle to thick. I just dont wanna have trouble starting the car.
What oil is recommended for the ZC cause they tend to burn oil alot? 10w30 or 40 5w30 |
I have always used 10w30 on my hondas but I use synthetic.
Re: (EyelessCRX)
I use 5W30 on my ZC never had a problem.... I wouldnt run 20W50 in any honda.... i recommend changing your oil buddy.
Re: (ghost_ryder35)
Re: (crxgator)
Here's a question kinda related to this, might as well keep it in the same thread...
Does putting a higher viscosity oil in your engine affect the VTEC activation? Take for example the new i-VTECs are supposed to be running 5W20 oil, that's like water. So does a VTEC motor need 5W30 as is recommended, or can 10W40 or 10W30 be used and make no significant impact on the performance of the engine? |
Re: (kamikazeCRX)
it can be used, but the thinner oil makes the engine not work as hard and gives you better mpg as well so im told on that aspect...
