Z6 swapped CRX Si....Couple questions.
Re: Z6 swapped CRX Si....Couple questions. (eg62come)
if you use your intake, fuel rail, and injectors, your stock si harness should work, then all you have to do is run a wire for vtec if you use a different ecu, or get a vtec controller
Re: Z6 swapped CRX Si....Couple questions. (crx_of_fury)
You want to convert your Si to OBD1 and use the correct OBD1 ECU for it.
http://www.rywire.com/sitodvtec.shtml
Under no circumstances do you:
A. Use the complete Z6 wiring harness in your CRX engine bay
B. Use both the cabin harness and engine harness.
90Rexx
09-15-2010 10:47 AM
hatchinprogress
10
07-13-2005 04:05 PM
