WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses
#51
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (Brewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brewer »</TD></TR><TR><TD CLASS="quote">Awesome, I gotta do it</TD></TR></TABLE>
ahhhh...dude...you got alot of work to do on my car...first a wire tuck then this...omg
#52
Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar »</TD></TR><TR><TD CLASS="quote">yea i saw it only comes in blue.. oh well doesnt bother me at all haha. found a black filter from aeromotive on summitracing.com if anyone was interested. </TD></TR></TABLE>
Oh man i forgot to put this one too,
- Part # - FI-7507-AN - -AN fittings included, High PSI fuel filter. 40 micron. 4000 GPH - $69.95
#54
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">summit has a black filter, and I have a site where you can get all the fittings in black, as well as black braided fuel hose.</TD></TR></TABLE>
link?
link?
#55
1 Post
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (88 rex)
http://www.amstreetrod.com/EarlsHoses.php4 hose
http://www.amstreetrod.com/Fue....php4 fuel
http://www.amstreetrod.com/HoseEnds.php4 ends
http://www.amstreetrod.com/Adapters.php4 adaptors
http://store.summitracing.com/...h.asp
summit filters, 10 pages
Ryan
Ryan
#56
1 Post
I have 1 q'n... I see 35 to 100 micron, if this is your only filter, what is best?? Highest micron?
Like do you always want to filter down to the smallest micron, or do you want a happy median for increased flow??
Ryan
Ryan
#58
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">I have 1 q'n... I see 35 to 100 micron, if this is your only filter, what is best?? Highest micron?
Ryan</TD></TR></TABLE>
i would like to know also
#59
Re: (Pee Wee)
well the smaller is better filtering. The system 1 is top of the line and its 30 micron. I say 30-40 micron should be perfect.
Also, i wouldnt get just any filter. I would get a trusted name. Like some of those filters on there are for carburated applications. You have been warned
#60
Smaller is better and two is better than 1. Something like a 100 micron after the tank and then a 30-35 in the engine bay.
#61
or you can be even stealthier and mount the same filter after the gas tank but before the fuel hard lines under the car and have no filter in the engine bay like me
#63
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (mr john)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr john »</TD></TR><TR><TD CLASS="quote">or you can be even stealthier and mount the same filter after the gas tank but before the fuel hard lines under the car and have no filter in the engine bay like me
LOL, sweeeeeet. I like my setup, deletes the banjo's
Thats pretty creative tho, whered u mount the filter at??
AND GO WORK ON MY BRACKETS HO!!!!!!!!
#64
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid »</TD></TR><TR><TD CLASS="quote">
I ordered this and it doesnt fit correctly, did you trim that stock piece, when we attach it, it only can catch 2 threads..did you have to modify the piece at all?
Part # - 9894DBH - 14 x 1.5mm -6 Female saginaw to AN male adapter - $5.87
(For this fitting use some teflon tape on the stock tube nut and dont tighten it with all ur might. It pretty much stops at a certain point so its not a big deal. Be careful tho just b/c the fitting is aluminum and the stock tube nut is steel.)
#67
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (K20EF8)
Nice setup.......the only concern I would have is all the color in the engine bay. Piggys like to look for that stuff, but that can be easily solved with some black or dark colored fittings/hoses. I like it
#68
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EF8 »</TD></TR><TR><TD CLASS="quote">I ordered this and it doesnt fit correctly, did you trim that stock piece, when we attach it, it only can catch 2 threads..did you have to modify the piece at all?
Aww man yeah, you have the kind with a space of no threads on the end...like this pic. Mine didnt have that it was just threaded to the end. Im not sure man, i'd try cutting it with a nice tubing cutter..
#69
Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses (crx2nr822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 »</TD></TR><TR><TD CLASS="quote">Nice setup.......the only concern I would have is all the color in the engine bay. Piggys like to look for that stuff, but that can be easily solved with some black or dark colored fittings/hoses. I like it </TD></TR></TABLE>
I would NEVER have a cop lookin under my hood to try and find stuff to ticket/fine me on or w/e.
#70
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid »</TD></TR><TR><TD CLASS="quote">Aww man yeah, you have the kind with a space of no threads on the end...like this pic. Mine didnt have that it was just threaded to the end. Im not sure man, i'd try cutting it with a nice tubing cutter.. </TD></TR></TABLE>
I have a small pipe cutter, so well try that.
#72
awesome, lemme know how that works out so i can add it to my write up. Make sure theres no pointy sharp edges after the cut, theres an internal o ring i think. Good luck
#73
1 Post
Ya, it needs to be flush to keep a solid seal on the pipe. Ill get some pix
Ryan
Ryan
#74
1 Post
The pipe cutter I had didnt sit flush because of the threads, so I couldnt get it to cut straight... I used a dremmel, and took the unthreaded section out... Then I used teflon tape. I think it turned out clean. Ill have pix of the end result soon
Ryan
Ryan
