Will 90-93 integra echaust fit on crx si......did serach
its off of a 93 two door i can get it for 100 bucks from friend. its 2.5 manderal
Re: Will 90-93 integra echaust fit on crx si......did serach (CIV616)
It's going to be too long. If you really want to make it work, I'm sure a muffler shop could trim it up for you, and they may have to bend it a little to make it work. 100 bucks is cheap for mandrel bent 2.5 https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Will 90-93 integra echaust fit on crx si......did serach (rodrez)
i just picked up an exhaust from an 91 integra and i'll be installing it in a couple of days. i'll let you know how it goes. i'm installing it on a civic.
Re: Will 90-93 integra echaust fit on crx si......did serach (irtep)
I have a 93 integra HKS hyper exhaust on my CRX.
it does not bolt in. it had to be cut and welded on three spots to make it fit. If you find a muffler shop willing to take the time to do a good job, I think it's worth it. |
Re: Will 90-93 integra echaust fit on crx si......did serach (Spaceballs the lunch box)
yes, i sold my tanabe to a guy with an integra, just needed it longer, opposite in your case, just need it shorter.
Re: Will 90-93 integra echaust fit on crx si......did serach (333)
so if i have a test pipe it should fit fine?
i know the 90-93 stock ones will fit for sure with just trimming the length of the pipe from a muffler shop will do..i was gonna do thi but had no time to search for on cuz of my tickets!! GOOD LUCK MAN!!!
