dash light problem!
Old 05-11-2007, 07:42 PM
EFcrxkidb's Avatar
Default dash light problem!
i have a 90 hf crx the dash lights dont come on at all i replaced the lights and checked the fuses the all good what can i do to fix this help quick not sure at night i can see how fast or what rpms nothing so n-e thing n-e body thankx in advance!
Old 05-12-2007, 12:13 AM
dgonzals's Avatar
Location: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
i am wondering does the car have a dimmer thingy a mobber.....if so adjust....if not....could be wiring...what is the history? did it just stop working?
Old 05-13-2007, 06:54 PM
ryyo's Avatar
Default Re: dash light problem! (EFcrxkidb)
Check to make sure the plug that goes into the dimmer is plugged in. You may also want to check to make sure that none of the wires to that plug are damaged. The only reason I'm saying this is because I was replacing my dashboard and failed to plug the dimmer back in, and the gauge lights weren't working. Plugged it back in, and everything was okay.
Old 05-13-2007, 09:15 PM
ludesrv's Avatar
There is a dimmer relay I beleive. They never die, but worth taking a look at. Other then the components like the switch, cluster, fuse, relay, it's wiring. At that point it's alot of work...
Old 05-13-2007, 10:12 PM
azhfreak's Avatar
i have the same thing . its the white wire on the far left , i have been tring to fix it for a week. .. not to steal your thread but if someone knows why mine wont work. could it be because i am using a diffrent gauge wire? (to lazy to go to home depot) . or know where i can take it and have them repair it and cost?
TurboPWR4
10-06-2008 09:51 PM
hugo7
11-03-2005 06:02 PM
CRXsiproject
10-19-2005 12:15 AM
OneZero1010101
06-10-2004 05:19 PM
TheJuggalo
09-03-2002 12:35 PM
Quick Reply: dash light problem!
