Whats the difference between a D15B1 and a D15B2?
I've heard many different things on the differences between the D15B1 and the D15B2. However I still don't understand the real big differences between the two, I mean WTF?? Can you guys help me out?
Re: Whats the difference between a D15B1 and a D15B2? (CRXSiBeater)
Keep in mind that the 90-91 STD (D15B1) have the same exhaust manifold as the DX (D15B2). The real difference lies within the intake manifold. The D15B1 has a restrictor plate which is what accounts for the difference in power output.
one is rated at 92 hp it has a si style exhaust manifold...other is rated at 70 hp..it has a exhaust manifold wih catylitic converter on it..reace with a si style and youd have a 92hp engine...both engine have same compression,bore,stroke,cam,pm5 ecu...just diff engine code since one ce with 4speed trans and crappy exhuast manifold
the STD has a PM9 and the DX has a PM5
the 88-89 STD has a cat on the manifold, 90-91 has a 4-1 design...
and i beleive the power relies between the ecu maps, and intake restrictor like wrong hand said
Re: Whats the difference between a D15B1 and a D15B2? (wronghand)
Don't make fun, it was 5 years ago!
Guest
Posts: n/a
Re: Whats the difference between a D15B1 and a D15B2? (JDM EF9)
sorry but u got the ecu's wrong
88 d15b1s have 9.6:1 compression stock vs the 9.2:1 of any other year.
d15b1 does have a restrictor plate in the tbody whch only allows for 1/3 the air flow.
d15b2 had a header similar to the si, d15b1 has a turbo manifold looking header with a cat bolted vertically to it then a 1.5" down pipe to exhaust.
d15b1 has a crap-o cam tat stops making power at 6-6200rpm
d15b2 has a slight mroe agressive one
if you want to eliminate the cat completely buy an si header and a STD b pipe. bolts straight up an eliminates the cat completely. the std b pipe is 2" diameter. this works for any 88-91 hatch
[Modified by TorteX, 11:33 AM 12/4/2002]
Re: Whats the difference between a D15B1 and a D15B2? (TorteX)
Not all B1's had the close coupled cat. Look at mine, it was a normal dx style exhaust. This may be a 88 only thing because every 89-91 std I've gotten parts off of has looked the same as mine.
Guest
Posts: n/a
Re: Whats the difference between a D15B1 and a D15B2? (nsxmatt)
could be. come to think of it, superhatchs gf's 91 std has a dx style cat
Re: Whats the difference between a D15B1 and a D15B2? (JdMB16Ahatch)
yes its an 88 thing we 88 std guys are cool to
I did bust a 10.9 60mph in the 1/8th with my gutted 4-speed std with intake, exhaust, and dx head
So with a 91 std (like me!) is there a difference between the existing exhaust manifold and an si manifold??? Would removing the restrictor plate and swaping the ecu with a pm5 work? or will i totally **** myself in the goat ***?
[Modified by 91 civic, 6:04 AM 12/5/2002]
gapergurlie_18
01-21-2006 08:51 PM
