start up problem, any idea?
Hello
my car recently developed some start up problems hopefully you guys can give me some insights.
Symptoms:
when i start the car as usual the car will turn over but then splutters, and eventually it dies.
then i try to start again it just wont turn over. I try to press the gas pedal to give gas but it seems no fuel is being sent (the needle on the tachometer wont move up at all and drops to zero).
After a several attempts (just turning the key as usual without pressing the gas pedal) ,it fires up and idle perfectly.
It occasionally happens in both cold start (after sitting for a night) or warm start (after having driven for like 10miles or more) .
Car is a 90 si complete stock.
Appreciate any inputs
Symptoms:
Re: start up problem, any idea?
Is your fuel pump priming? Do you have fuel pressure and what is it? When was the fuel filter last replaced? What mileage on the car? Has the main relay ever been replaced?
That's just the first couple questions that come to mind - gotta have more info to narrow it down.
My mechanic had done a tune up, which includes new plugs and wires, oil change, timing belt, water pump and etc) on my car and the start up problem seemed to go away until yesterday.
Symptoms:
Car is a 90 si complete stock with 100k on the clock.
Any input is appreciated
so finally got around to check on the problem.
I checked the main relay module and it appears to be good after following the diagnosis on factory manual.
the fuel pump, as far as I can tell the priming sound is intermittent. if there's priming (I believe it last for around 1 to 2 secs), then the car starts up.
if there isn't, it wont start.
Sometimes if it starts up it might stalls then die right away no matter how hard I step on the gas, it just wont rev up...…..
so all said, is my fuel pump going out?
My understanding is Honda fuel pumps are very reliable. I would look at your engine coolant temperature sensor. Jump the plug with a paper clip. See if it starts. If the sensor fails it will flood your engine with too much fuel. Since you think it may be a fuel problem. Take off the fuel line that goes to the fuel injector rail. Put the fuel line in a bucket. When you turn on the key it should put a bunch a fuel in the bucket. If it does not. Check the ignition switch for a bad contacts. It comes apart and you can scrape the metal with a screw driver. I've had both off these issues with me 93 accord. The most recent was the ect sensor. It would start intermittently. Once it started it ran fine.
I'm not going to claim the ECT can't be involved, but my (admittedly very limited) understanding of OBD0 indicates the ECT should not be critical to startup. And while I'd agree with the previous statement that Honda fuel pumps are reliable, keep in mind that an original pump is thirty years old. Failure is going to occur eventually - it could be now.
If priming is intermittent as your ear indicates but the relay tests good, then first check wiring to (hopefully) see if that is good. Next will be dropping the whole tank to get to the pump, and enjoy one of the worst parts of having an ED/EE/EF... try to remember that the most of the car was designed better than this.
Fuel pump. It’s easy unplug it and it’s two bolts to drop the tank. Make sure you get the right strainer too. You’ll have to find that YouTube vid but it’s out there it’s $25 too but it’s the right one even for my 90 sedan and don’t pinch the fuel line when you put the tank back up. if your problem doesn’t go away and just changes a little return the pump and try another one.
thanks guys for all the inputs
so does the below symptom sound like ignition switch related or fuel pump related or both?
so i replaced the ignition switch and doesn't seem to solve the problem.
i ran the fuel pump test by shorting the 2 pins on the main relay harness as below and there's continuous priming sound.
9. Connect a jumper wire between the BLACK/YELLOW wire (pin 5) and the YELLOW/BLACK wire (pin 7).
10. Turn the ignition switch ON.
however, when i reinstalled the main relay, turn the ignition to ON position and i don't hear any fuel priming, do i have a bad relay? I also ran a relay test following Factory service manual instruction and everything checks...…..
Any idea?
Any idea?
Not sure why you needed to replace the ignition switch. Have you checked the wiring to the pump? Did you figure out when the fuel filter was last replaced?
