Timing Belt shredding- pic included
This is my 91 CRX that has a z6/b7 mini me installed. After some distributor issues and replacing the valve cover gasket and grommets, i put everything back together, fired her up and SMOKE and timing belt everywhere.
This is what it looks like now:
I'm thinking I might have dropped a screw down it or something. What do you guys think?
Also, how hard is it gonna be to take off the bottom cover to check?
Re: Timing Belt shredding- pic included
Finally got everything how i wanted it and this happens. Am I gonna need to lift the engine to get at anything?
tensioner too mm? I actually don't think that was replaced when I did the swap.
shows how much I Know
So this whole problem is fixed.
Ever since it started running again it has a weird "whine".
Whenever I shift the whine Sounds like it whines down.
It doesn't whine if I step on the gas in neutral. Any ideas?
Also, my hids turn off soon as I step on the gas. Thanks for any help!
Contact Synchrotech.
cehcivic15
01-08-2009 10:18 AM
VTHokie
07-23-2002 07:47 AM
