Tach problem
Tach problem
uh i just swaped a b16a in my hx hb...i tried to install a tach... but i cant seem to figure out where to put the green wire.. my 98 civic was easy its was the same color as the wire... but with this no green wire to put it in.. any info on wat wire to put it in to get a rpm reading...any info will help thanks
There's a blue wire going to the back of the cluster that you supposedly can tap into. I couldn't find it so I spliced into the dizzy plug.
There are two plugs at the dizzy. One plug is smaller and only has two wires in it. The blue wire on this plug is the tach wire. Just splice into it and ur golden.
