Swapping AT to MT
Ok Im swapping my ef civic dx. It as an automatic tranny in it. What shift linkage do i need to use or does it matter since i have to cut the hole and mount it anyways? and what else do i need besides the pedal assembley?
Re: Swapping AT to MT
Get a linkage from a ef. The pedal assembly, clutch cable. A manual trans fly wheel. And a little bit of wiring I believe.
And a manual trans of course
Ok, I've heard you have to swap out the trans mission mount pocket on the passenger side?
A manual trans and manual trans mount and it will be good to good.
ok cool. but what if im swapping in a b series?
this has been covered many times
use the search button Pm5/6 ECU ( sepending if staying dpfi or mpfi ) 88-91 SOHC manual transmission pedal assembly of 88-91 civic/crx/sedan linkage off 88-91 civic/crx/sedan rear/passenger side shock tower motor mount bracket off 88-91 civic/crx/sedan (m/t) clutch cable off 88-91 civic/crx/sedan flywheel/clutch for 88-91 civic/crx/sedan you will also need the flywheel/clutch bolts Flywheel- 12point 17mm bolts clutch- 12pt 10mm bolts ( You NEED the 12pt sockets to get these off, no ther sockets will fit,if you try you will strip them first try ) these are just parts you need. you will also need to do some wiring. you will also have to plug the transmission hoses coming from the radiator ( idk if you NEED to, but better safe than sorry ) |
I was going to type it out but meh
thanks, thats gonna help alot
This thread was beneficial for me. B series will be slightly different, of course. http://www.gassavers.org/showthread.php?t=1033
Only wiring you need to do is the reverse lights
thats a good write-up
Originally Posted by fog raw
(Post 46662450)
just to clarify, theres a 2 pin plug on the auto shifter assy, take that plug, it will have 2 wires, both are black with a white stripe, these wires need to make a connection so the starter will recieve its signal when starting. |
This helps alot you guys, thanks
This is probly been answered b4 but i couldn't find it when i searched for it. Will an automatic for a d series motor bolt up to b18a1? If not how hard is it to us a b series AT in my ef hatch?
Originally Posted by 91 EF DX
(Post 46668248)
Ok im just going to do the AT to MT swap. Do yall think it is possible in 5 days? Doing the dpfi to mpfi and AT to MT with a b18a1 in my ef dx hatch?
