rear fender flaring
wat up i have a question so i need to flare out my fenders im running 15 with 10 offset the front ones are cool but the rear hit bad lol was wondering what methods can i use to flare the rear out thanks
Re: rear fender flaring
Use a piece of 2" pvc pipe, wedge it between the tire and the metal and roll it back and forth slowly. if you use schedule 80 pvc its thicker and stronger. Also if you take a very sharp razor blade and CAREFULLY cut your paint right at the bottom edge of the curve then when the metal stretches hopefully the paint stops chipping off right where you cut it. Also cover up the bare metal as soon as you can so it doesn't rust. Take your time and it'll look good. Also if you cant fit the pvc between your tire and the edge jack up that corner a bit but leave the tire on the ground, or engage your ebrake
aite tanks
i suggest you to go to good locksmith so,that you can be free from that problem with less cost rather than making it more worst.
