REAR DISK BRAKE CONVERSION w/pics - Page 3 - Honda-Tech - Honda Forum Discussion
Old 03-16-2007, 05:29 AM
  #51
be professional
Targa250R's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">3040. non abs Si</TD></TR></TABLE>
Now that's some detective work.
Do you know of other vehicles that came with a valve stamped 3040?
Targa250R is offline
Old 03-16-2007, 11:20 PM
  #52
crx_si-r's Avatar
alright everyone since i had a somewhat huge hit with this post from a couple of weeks ago, im gonna be doin the rear brake conversion on my hatch this weekend. ill take more pics and re-create this post and maybe it will make it into the FAQ's wat du u guys think? hopefully i can get it done without droppin the tank and in less time. thanks all.
crx_si-r is offline
Old 03-17-2007, 02:54 AM
  #53
EF_PINOYGUY's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Great write up!
However there is no need to drop the tank at all. I have done several brake conversions on CRX's and hatch's it is not something that needs to be done. All bolts, and cables can be removed easily without dropping the tank. </TD></TR></TABLE>
That what i was thinkin!...I was like thinkin too myself "dam, I didn't have to drop the gas tank" "how the hell did i mange that lol!'..Had me there for a minute..I did my conversion for the first time last month on my 90 si and it was pretty fun..Only thing i hated was laying underneath the car takin all the dam 12mm bolt's holdin the e-brake cables off cuz dirt kept fallin in my eyes until i got smart and put my safety goggles on lol.. other than that, Mr. Hydraulic jack is your best friend & helper when your doing it yourself..Bolting on the Rear trailing arms can be stubborn and kill's your arm's..
EF_PINOYGUY is offline
Old 03-17-2007, 03:16 AM
  #54
Default Re: REAR DISK BRAKE CONVERSION w/pics (EF_PINOYGUY)
subscribed
Skipper75 is offline
Old 03-24-2007, 10:17 PM
  #55
Mad_Scientist's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Skipper75)
If i have Goodrich Steel Braided lines made for rear drums and i convert to disk can i still use the line?
Mad_Scientist is offline
Old 03-25-2007, 01:38 AM
  #56
azhfreak's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Mad_Scientist)
i have a 1991 honda civc hatch dx, what year and model car rear disc brakes would directly bolt on. and if its not to much list parts i need to get to do the conversion. i am still mostly honda noob so no flaming. thanks
azhfreak is offline
Old 04-01-2007, 11:35 PM
  #57
superhatchbackbros's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (azhfreak)
Parts needed :
90-91 crx si rear disks setup
90-93 integra E-Brake cables
Parts you can use if you wanted to make a lil better setup :
90-93 integra 40/40 prop valve
90-91 civic EX 4dr master cylinder
90-91 crx si steel braided brake lines
hope that helps .... but best way to check it out is to use the search button there is many forums with pics about this
superhatchbackbros is offline
Old 04-01-2007, 11:51 PM
  #58
Tyson's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (superhatchbackbros)
can you please stop calling these prop valves "40/40"!
its 4040
Tyson is offline
Old 04-03-2007, 04:11 PM
  #59
i got a 4040 valve forsale $30 if anyone is interested just hit me up
Forsale thread:
http://www.hondamarketplace.co...86184
Old 04-21-2007, 05:06 PM
  #60
JDM*addiction's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (crx_si-r)
would be really helpful if this was a little more clearer..(more indepth)
deleting the stuff about dropping the tank would help out alot. and how remove ebrake cable and put the new one on
JDM*addiction is offline
Old 04-21-2007, 05:44 PM
  #61
l1bid0's Avatar
I used the 4040 one on my car and it seems fine. Your rear will stick out more if you use the ones from a integra. I'm running 195/50 15's on my hatch and when I take hard turns or normal turns with people in the back it will rub on that plastic lip. I'm hesentant about removing the plastic right now. It looks 100% better then drums
l1bid0 is offline
Old 04-23-2007, 05:22 PM
  #62
Agent_EM1's Avatar
good job... my civic got stolen...
Agent_EM1 is offline
Old 05-05-2007, 06:09 AM
  #63
soodominican's Avatar
hey bro
the write up was good shouldnt worry bout it..
i gotta quick question..see i gotta 91 sedan i jus got the car and im startin to buy parts for it... one thing i really wanted to do was a brake conversion...but ppl have told me if i do a teggy rear end conversion than im gonna need teggy shocks...is dis true? or will civic shocks be good?
soodominican is offline
Old 05-05-2007, 07:05 AM
  #64
be professional
Targa250R's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (soodominican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soodominican &raquo;</TD></TR><TR><TD CLASS="quote">one thing i really wanted to do was a brake conversion...but ppl have told me if i do a teggy rear end conversion than im gonna need teggy shocks...is dis true?</TD></TR></TABLE>
No.
Old 05-05-2007, 02:20 PM
  #65
nexgen91's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Targa250R)
gotta quick q, I converted my CRX to drums to have disk for my hatch and now the crx makes a hissing (vacume (sp?) leak) noise when I turn it off, coming from the BB. What the hell could be wrong? Maybe not tight enough?
nexgen91 is offline
Old 05-05-2007, 02:26 PM
  #66
Hybrido_90Civic's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (nexgen91)
Great write up. I also did this on my 90 sedan from a 93 Integra and they fit perfect.
Hybrido_90Civic is offline
Old 05-05-2007, 10:48 PM
  #67
EFM_ookie's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Hybrido_90Civic)
i have a question... i just did my rear brake swap on a 88 dx.. i just used the 88 LCAs and struts... will i have any problems with them?? are the da LCAs different in length?
EFM_ookie is offline
Old 05-06-2007, 12:18 AM
  #68
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">can you please stop calling these prop valves "40/40"!
its 4040
anyone konw the part number for the 40/40 valve? lol. no really i need a new one and can't find it on the onlinr acura parts store.
abnaasefmb is offline
Old 05-06-2007, 07:33 AM
  #69
92_Lx's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (abnaasefmb)
what all do i need to do a rear disk brake conversion on my 92 lx 4dr a buddy of mine has some like new 99 si rear disk brakes would those work or no plz help thanx
92_Lx is offline
Old 05-06-2007, 07:56 AM
  #70
DaNnYsEvEn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">
anyone konw the part number for the 40/40 valve? lol. no really i need a new one and can't find it on the onlinr acura parts store.</TD></TR></TABLE>
awwww ****, tyson gonna throw a fit. lol haha
DaNnYsEvEn is offline
Old 05-06-2007, 02:17 PM
  #71
be professional
Targa250R's Avatar
46210-SK7-Q01 VALVE ASSY., DUAL PROPORTIONING $175.15
Don't buy a new one.
https://honda-tech.com/zerothread?id=1970626
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_Lx &raquo;</TD></TR><TR><TD CLASS="quote">what all do i need to do a rear disk brake conversion on my 92 lx 4dr</TD></TR></TABLE>
Search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech.com Search &raquo;</TD></TR><TR><TD CLASS="quote"> Search Results
Your search for disc returned 200 results.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">a buddy of mine has some like new 99 si rear disk brakes would those work or no plz help thanx</TD></TR></TABLE>
Yes.
Old 05-06-2007, 02:23 PM
  #72
nihad's Avatar
u could of just switch the spindles not the whole arm . and dont need to
mess with the gas tank
nihad is offline
Old 05-06-2007, 09:34 PM
  #73
abnaasefmb's Avatar
you da man! i have an old one but my brakes just don't feel right and i'm thinking i might just buy a new one and some ex knuckles and brakes.
Old 05-09-2007, 06:44 AM
  #74
Player_One's Avatar
Depends if you swapped out for a different style of rear lower control arms. There's the fork style shock and the bushing style shock. The ends of the fork attach on the outer ends of the LCA while the bushing style attach on the hollow inside of the block shaped LCA.
I believe the Integra Type R and the CRX may have the block style LCA which use the bushing style shocks? I'm sure that 5th gen Civics, Del Sols and 3rd gen Integras have the LCA using the fork style shocks.
Player_One is offline
Old 06-03-2007, 06:59 PM
  #75
skater4145's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Do not, I repeat, DO NOT use any arms from the Integra other than the trailing arm, or else you will have major wheel alignment problems. The trailing arm is the ONLY arm you can use from the Integra.
is this something that connot be fixed by having a wheel alignment done?
skater4145 is offline
Quick Reply: REAR DISK BRAKE CONVERSION w/pics
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
