what are these pins for on the interior fusebox?
Re: what are these pins for on the interior fusebox?
the last two on the right in your red circle are for the fuse puller. its a little black tool that comes stock with the car. those two spaces can be used to hold your fuse puller.
the other three.. not sure bro.
those three spots are actually a source for constant power. put a test light on it and ground and check it out. You'll see
There are actually 5. 2 up top (1, 2) then those 3 (3, 4, 5).
So 3, 4, 5, are constant, switch, and running lights? in that order?
DO IT ON ALL FOURS
1. = 12v Key Position 2
2. = 12v Light Switch Activated (turn pos. & headlight pos.)
3. = 12v Key Position 1 & 2
4. = ??? I am not sure and I am pretty sure it is not a ground...
5. = 12v Constant
Wrong... they are not in that order I am curious where people ge their information from...
5. = 12v Constant
5. = 12v Constant
Lol pretty sure its not a ground eh?
DO IT ON ALL FOURS
Well I tested it and I can't get voltage from it either positive or negative going through the motions. So I took a test light and hooked it up both ways (positive source and negative source). Then I cycled through the key positions (yes, even pos. 3 (start)). I could not get it to function as anything be it ground or positive source in any key position. It must be for something else or is switched by something else. I personally was really hoping it would be a ground.
Gatschet
23
08-25-2021 10:35 AM
hiredassasin19
20
04-05-2010 12:55 PM
Luke G.
10
09-27-2009 08:32 AM
