PM6 ECU |?
PM6 ECU |?
ok i have a dpfi d15b2 engine right now, all i am planning on doing right now is converting to mpfi and im gonna use a pm6 ecu, in the future im planning and swapping a vtec head on the car i just want to kno if the same ecu that i will hav will work with the vtec head
Re: PM6 ECU |? (Layziebtnh055)
It wont activate VTEC but it will run the motor fine. If you use that Ecu you will need to get a RPM activated switch or a VAFC for the VTEC to work
1 Post
Re: PM6 ECU |? (MENACE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE »</TD></TR><TR><TD CLASS="quote">It wont activate VTEC but it will run the motor fine. If you use that Ecu you will need to get a RPM activated switch or a VAFC for the VTEC to work</TD></TR></TABLE>
all correct. However I would suggest a VAFC over a RPM switch (even tho the vafc is more expensive) because it would be better for controlling the fuel.
senior gold member
Re: PM6 ECU |? (crx_88_si)
instead of spending on the vafc I would go to obd1. Thats just me though. The vafc would help you control fuel too but I think the obd1 ecu would be better in the long run.
Re: PM6 ECU |? (Ivan)
you will have to get a 92-95 Si or EX computer for it for the vtec to work. Edit: nevermind im an idiot. I would go vafc with an RPM switch for fuel reasons also
Re: PM6 ECU |? (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee »</TD></TR><TR><TD CLASS="quote">whats the difference between PM6 and PM5 ecus?</TD></TR></TABLE>
I think the PM5 is the DPFI ECU and the PM6 is the Si ECU
And to answer the origanal question...I would convert to OBDI and just run the P28.
Re: PM6 ECU |? (96-EJ6 B18C)
run the p28 and call it a day, that way u dont have to deal with all the extra wiring of **** that can be taken care of by using a p28
