Phantom Grip LSD install B Series transmission.
#27
Re: Phantom Grip LSD install B Series transmission.
d.d. and its hops a little bit and turnings kinda a bitch but nothing I can't deal with. and I never have to worry about it not locking up
#28
EFB055
#29
no problems yet. and not too much of a worry wort about that sorta stuff. haven't broken a axle in two years.
#30
#33
Hello Honda-Tech brethren (and sisteren),
Mod's If I am in the Wrong thread/section please feel free to move. I mainly hang out in the 88-91 EF section and rarely poke my head out.
Before I start this Build I would like to say that yes.
I do realize that the Phantom Grip (P.G.) line of LSD products are considered by some to be a waste of money.
But I think that a lot of this hater info is mostly passed down through the grapevine (noobs) and not based off of experiencing the Spring loaded LSD.
I have nothing against the product and know many who love it as well as some whom hate it.
SOOOO!! That said lets start (by reading this you certify that you have enough mechanical knowledge to do this and i am liable for nothing..... Right???!?)
Step 1. You should have a nice solid work area to perform this task, some good ole WD-40 a good set of quality punches a set of dikes a small screw driver and a nylon padded ball peen hammer or other hard material mallet.
Step 2. Tear down. I will not go into this because it is very well covered by SEARCHING! Here is a Very informative Build Thread by HONDABULL http://www.ht-archive.com/showthread.php?t=2443459
as well as a VERY KILLER video by Evans-tuning http://articles.evans-tuning.com/200...-differential/
Step 3. Diff is out.
There is a little skinny spring pin (some call bitchpin?) in this little hole.
It must be tapped out from the reverse side of the Diff (opposite side of reverse gear). I find that spring pins like to be sprayed with WD-40 and tapped out slowly and straight. I also swear by these kinds of punches since they have a bevel/recess to avoid "flowering" the end of the pin.
If you use a Nail or Screwdriver or some other thing besides a nice punch you are on your own, My cheap friend!
Step 4. The spider pin should move like butter and slide right out but sometimes it may need some persuasion. use the Nylon padded hammer.
Step 5. This ring gear bolt needs to be removed in order to clear a path for the P.G. Remember that these fine thread bolts are REVERSE THREAD clearly marked on the bolt head.
Now you should be here and the Phantom Grip is almost ready to move into its new home! (between spider gears)
Step 6. Eyeball the hole in the Phantom Grip and ensure that the hole lines up with the Spider Gear pin holes and push the pin into the assembly until it stops early (It will not travel all the way in).
Step 7. These are spring pressure retention plates/pins. They can now be gently pryed off with a small screw driver they "pop" off so dont crap your pants.. Go slow and easy until the plates come off.
Remove pins.
Step 8. Spray some good ole WD-40 and start tapping the Spider gear pin while keeping mind that the Spider Gear pin has a hole which must be aligned with the hole on the Diff. The Spring pin goes in there.
Step 9. Almost done! Clean the Spring pin as well as the Spring pin hole with brake Cleaner/Carb Cleaner. Install spring pin the way it came out (see photo). I use some red Loctite on the spring pin for added security.
Keeping as straight as possible tap the Spring Pin into the Diff until it sits flush.
Step 10. Gather all these pieces!! You do not want them in the diff. Trash em!
You are done. You deserve a beer.. Assemble tranny and go to your Race Track and give the P.G. a try!!
After thoughts? None really. I will post up vids and pics in my build thread when I am done. I got the P.G. brand new for 120bux off a friend so I took an hour and put it in. I understand the principle behind how this works. And it is based off a good idea so What the hell.
Cheers!
Remove pins.
Cheers!
#34
I dont care if these aren't as good as a helical or plate diff, I just want to know if they are truly better than an open diff, and if they last. I look forward to your testing.
#35
word im more interested in the testing involved in one of these. a good write up is good but doesn't prove the product is great in my book.i still feel the PG is more of a band-aid for a lack of lsd and the longer you have it installed the worse it is on the spider gears. then again i would do this on a d-series transmission lol.
#37
#41
#42
Well its not exactly grinding against any gears.?!
It pushes the spider gears out and locks up the pin gears. I do have a magnetic drain plug along with the factory Magnet sweeper. My car is almost done with its Super poorman build!
#44
I am hoping that with the camry lip, beat up Lic.Plate and old ls mesh's I can stay away from tickets! lol
#45
I believe it was OPM motorsports or something that had a open-differential conversion similar to the Phantom Grip but was more complete(I'm under the impression it didn't load the spider gears; spider gears were replaced, probably with clutches like regular clutch/plate LSDs).
#46
Okay here is a good comparo of a guy whom was selling his PG used on ebay. The guy runs a boosted b16 and pushes that thing. He got his hands on a CTR tranny and sold his PG. I dont see wear on it?
Used PG pics
New pic.
Used PG pics
New pic.
#47
Either way it is in there and not coming out unless I hate it.
Performance updates soon. I have to break in the engine first.
#48
The unit itself doesn't wear out, the spider gears do. Or both. Think about how it works.
The most abuse the part would see is actually in road course, where the spiders would be turning at different speeds for longer periods of time. Luckily, I guess, not much if any road course guys use that part.
Keep it in there if you wish, no body is arguing or telling you to take it out. Just informing, and what to possibly expect.
#49
Yeah, I haven't seen a good explanation on how these things exactly work and what exactly take the beating here. My crappy guess would be that the gears that the PG are pushing outward on are directly connected to the axles. So if the axles are rotating at the same rate, there is no wear on the gears or the PG because its moving as one unit. As soon as the axles move at different rates, that's when there is friction and wear on the diff carrier, gears and PG. Unless there was something you install along with it to take that abuse, I'd rather just get an OBX and rebuild it for about the same price. I want to see the result of this! lol A teardown and inspection after some serious abuse!
#50
First pic i can see alil bit of wear in not much tho how long was it used?
i wonder what his spider gears look like?
