Online B16A Swap list???
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Dont give me the "do a search" speech does anyone know of a online B16A parts list for a crx. I thought I have everything but I feel that I am missing something.
This would be greatly appreciated!!!
You need:
b16a tranny
b16a engine
b16a mounts for your car check with hasport
axles
wiring
computer
shiftlinkage for your setup
intake
header
exhaust
tools to do the swap
air tools help![](https://honda-tech.com/forums/images/smilies/emsmile.gif)
k thats all i could think of off top of my head.
DEF
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
air tools help
DEF
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 »</TD></TR><TR><TD CLASS="quote">You need:
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
DEF</TD></TR></TABLE>
:beermug:
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
air tools help
:beermug:
Don't need tools, because I am not putting it in myself.
I have everything that you stated "including the beer mug", but you dont need to change intake/header/exhaust though do you? Thats just what they recommend i thought?
But other than that, I have in that list....but I still feel like Im missing something???
A Write-up by blac_krix_si Taken from the Resource:
B16 parts list updated
Its seems the same exact questions have been coming up every 5 minutes, I took the B16A1 parts list that 88DXCRX provided and added a few things to it. The original is MIA since the site went down
*Distributor Locashracing.com has new OBDO for $275
*Distributor Hmotorsonline.com has used OBDO for $150
*Transmission Oil Seal. Beck/Arnley #0523545
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol **this did not work for me, too long. I used the D16a6 Si belt**
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
*Shift Linkage Pin A94305-80222
*Shift Linkgae Pin Clip A54113-611-010
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK---- Stock Number 5724 in case they cant use the NGK #
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
*The rubber seal for the distributor cap is 30132-PM5-A02 (90-91 Integra)
*NAPA part #25-040300 for the alternator and a/c
Now, you don't need all of these parts to swap the motor. However it will be handy to keep this list saved on your hard drive if you ever need to replace anything on the motor.
If you use 90-93 NON ABS Manual Integra Axles you will need a 90-93 NON ABS Manual Intermediate shaft.
ECU should be PW0 or PR3. PW0 is from the 1st generation SIR motor. PR3 is from the Integra XSI motor.
You don't need new exhaust, however it would be nice to replace at time of motor swap.
Some B16 motors come with factory header and downpipe. If it does not come with either, then you will need a header and downpipe. I happen to have 2 stock B16 headers and 1 stock downpipe. Your old D Series header will not fit on the B16 motor.
Also, if your current car is an HF model then you will need to upgrade your knuckles and hubs on your brakes to those from an SI or DX. I chose to swap the whole brake system over from a 91 Civic LX. Same as SI and DX basically.
Realistically, that is all you need, unless there are any sensors that need replaced on the B16. Not all B16's come to us perfect, but that's why you order from a respected seller like Hmotors or Nippon. Everyone has bad experiences so let's not make this a bash on JDM Motor distributors discussion.
Good luck and if you have any more questions feel free to PM me.
Originally Posted by deftones0817
You need:
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
air tools help
DEF
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
air tools help
DEF
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
Location: I told you to wait in the truck in Texas, United States
If you will look in the "FAQ" post at the top of the CRX/EF Civic forum,
There are several good B-16 links posted there...
Most of that info came from a guy named "Monty"..
https://honda-tech.com/zerouser...07509
Thanks to him for that..
well that post this time came from the resource
and it was on there for I good while before they had to redo everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 »</TD></TR><TR><TD CLASS="quote">well that post this time came from the resource
I know.. that is where I am from also..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEF »</TD></TR><TR><TD CLASS="quote">Add the throtle cable bracket & Clutch cable I also think u should add a new fuel pump too</TD></TR></TABLE>
why a new fuel pump?
1 Post
Well one time at the shop we did a b16 swap in to a dx , after a week or 2 the fuel pump took a crap . So we always recommended to upgrade it to like a gsr pump.
HATCHingMN
02-02-2004 04:12 PM
TheHatchHog
05-09-2003 10:30 PM
0523545, 15400poh305, b16, beckarnley, cable, camshaft, changeover, integra, list, nippon, obdo, oil, seal, swap, throttle, transmission, xsi
