OBD0 DPFI --> OBD1 Distributor Wiring?
I made this little diagram, so hopefully someone can make sense of it and fill in the blanks. That way I can get this dizzy wired up and future swappers can learn from it also.
OK, so I am putting an OBD1, TD-41 distributor on my A6. I took the male side of a dizzy plug from the junkyard and left the wires on it so that I can wire my harness to them and pretend that it never had a DPFI, OBD0 plug on it. My engine harness is DPFI, so I added the two wires into the harness already when I swapped the A6 in. (C21 and C29) Basically, I just need to know which wire to solder to which so that instead of having an OBD0 male plug on it, I will have an OBD1 male plug on it. The top plug is already done, that's only a 2-wire. https://i14.photobucket.com/albums/a...Blackboard.jpg If someone can button it up like this: 8->6 9->1 12->3, etc. That would be SO appreciated. I just couldn't find a diagram pertaining to my situation. https://honda-tech.com/forums/images/smilies/emthup.gif |
BUMP
Just grab a voltmeter and trace the wires from the ECU.
The I made the obd1 diagram below a while ago, and its 100% accurate. The obd0 diagram should be accurate also, but i just made it. Using the below info and voltmeter, it should be very easy to get your wiring sorted out. Let me know if you have any other questions. OBD0......OBD1 ------------------ [b10].......[b11] --> cyp P aka cylinder position [b12].......[b12] --> cyp M aka cylinder position [c3].........[b13] --> tdc P aka top dead center [c4].........[b14] --> tdc M aka top dead center [c1].........[b15] --> ckp P aka crank position [c2].........[b16] --> ckp M aka crank position [b15].......[a21] --> Ignitor signal http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D http://www.we-todd-did-racing.com/we...EzZGZkMzF5NTQx |
Re: (l1bid0)
I took that out of https://honda-tech.com/zerothread?id=1349052 thread. That's what i used.
Re: (l1bid0)
Hmmm...
Anyone else? I'd like to just match up the wires and solder them together. |
Re: (Tippyman)
Anyone done it this way before, and can confirm the wire colors to match up?
Re: (Tippyman)
Thanks to this diagram, I have figured most of it out (I think.)
https://i110.photobucket.com/albums/...structions.jpg However, the C1 and C2 (C21, C29) wires are still undecided. The CKPG goes to blue/yellow, the CKPP goes to blue/green. Which wire is the CKPG and which is the CKPP? |
Re: (Tippyman)
Ok, I think C1 goes to blue green, cause that is the CKPP. https://honda-tech.com/forums/images...es/emsmile.gif
Re: (Tippyman)
Sooo... via process of elimination, I decided that:
10 ----> 4 11 ----> 6 12 ----> 3 13 ----> 5 (Large) 14 ----> 1 (C1) 8 ----> 2 (C2) 9 ----> 7 Orange - Peach White/Blue - White/Blue Orange/Stripe - Peach/Stripe White - White Large White - White/Green CKPG (C2) - Blue/Yellow CKPP (C1) - Blue/Green C1 C3 C5 C2 C4 C6, etc. There. We'll see if it works. https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: OBD0 DPFI --> OBD1 Distributor Wiring?
Ok so I'm at the same problem I'm using a dpfi engine harness and i already did the mpfi on the inside and then did a jumper harness to obd1 ecu and I also ran a obd1 injector harness straight to my ecu... So know I just need to know has to convert my dpfi harness to my obd1 dizzy I already ran the 2 wires out the fire wall Any help on this
