d15b1 to d16z6 swap questions
Old 06-04-2013, 12:52 PM
alexzhere's Avatar
Default d15b1 to d16z6 swap questions
okay so I have a complete d16z6 engine and I want to put it in my 91 civic with a d15b1 currently in it. Can I use the z6 harness with the p28 ecu or do I need to convert to mpfi and obd1 first?
Old 06-04-2013, 12:56 PM
Keyboard Humorist
4drEF's Avatar
Default Re: d15b1 to d16z6 swap questions
You should not use the Z6 harness.
It will not plug to the firewall connectors.
You should do the DPFI > MPFI
and OBD0 > OBD1
Old 06-04-2013, 01:21 PM
alexzhere's Avatar
and OBD0 > OBD1
Will my b1 harness work with the z6 and also how should I wire vtec?
Old 06-04-2013, 01:31 PM
Keyboard Humorist
4drEF's Avatar
GOOGLE
DPFI to MPFI
- about 12 steps that you need to do to the existing B1 harness at the ECU as well as under the hood.
OBD0 to OBD1
- a jumper harness that you buy that allows you to plug in the P28 ECU to your existing harness. Decent jumper harnesses include all the information you need for hooking up vtec.
Old 06-04-2013, 01:35 PM
alexzhere's Avatar
GOOGLE
DPFI to MPFI
OBD0 to OBD1
Okay thank you very much. I tried using google but for some reason I couldn't figure it out. But it seems fairly straight forward now.
nightscream
11
10-28-2010 04:02 PM
what the ef
04-18-2010 09:09 PM
daredeezy619
11-21-2008 04:38 PM
KURUPTinc
08-14-2005 10:43 AM
SOHCEK-Turbo
08-12-2003 01:41 PM
Quick Reply: d15b1 to d16z6 swap questions
