JDM OEM parts website like www.hondaautomotiveparts.com?
I said I don't want a title!
I'm looking to see if anyone knows of a website that gives OEM part numbers/exploded views like several we have here in north america, such as http://www.hondaautomotiveparts.com/
Trying to look up a tiny part and I can't find a NA equivalent (yet). But if I had the part number, I could cross-reference.
Re: JDM OEM parts website like www.hondaautomotiveparts.com?
Or if not...maybe this will help. I need the little piece that 'anchors' the center of the JDM OEM LED 88-91 rear hatchback wing to the top of the hatch.
On the USDM cars, it's a little plastic piece in the middle that clicks to the wing and to the hatch. I have that part and that isn't it. The JDM wing part is different and I'd like to find the actual part itself.
#44 on this image. The part is different between USDM and JDM. I need the JDM part:
http://www.hondaautomotiveparts.com/...cgry5=TAILGATE
Do you think this might be the same for the Canadian market? I can definitely probably source one from Canada if thats the case. Japan, would be a nightmare.
1 Post
Can you be more specific about the SiR? I just looked up a 1991 Canadian Civic Si, and SE 3dr, and also a US Si 3dr and then a JDM SiR2 EF9-110xxxx and came up with the same part number for all of them. Then I checked a 1991 Civic 3dr VT from England and found the same part number:
91505-SH3-003
Don't know if I'm comparing apples to apples regarding the JDM SiR and my knowledge of Civic model differences is somewhat limited, so if you have additional info, please let me know.
91505-SH3-003
So I looked at the links and yeah--that clip is the same for all markets. I really need to take a pic of the USDM hatch rear wing (bulb) vs the JDM hatch rear wing (LED) as the "attachment" in the center is obviously different.
If it is not that clip, then it is something that it clips into on the wing itself. Checking the other parts looked the same as well. I'm confused, so hopefully pics I take will help the cause.
Wait a sec...maybe there is a difference:
In this diagram: http://www.crxsi.com/jdm/ef9-1101532...-Tailgate1.htm
There is a 'USDM' style rear wing and the JDM LED style rear wing.
USDM part:
53 CLIP A, RR. SPOILER 91505-SH3-003
JDM LED part:
66 CLIP A, RR. SPOILER 91505-SH3-000
If "91505-SH3-000" is correct, this part was available in the US as a 96-97 3-door Civic CX part!
USDM part:
JDM LED part:
USDM part:
JDM LED part:
USDM part:
JDM LED part:
I have confirmed that they are the same part. "000" updates to "003"
Also had no luck finding a JDM number for you.
#44 here (89-91 Civic Si), 91505-SH3-003:
The part looks completely different. Do you have an online reference as to where one supersedes the other?
And if you look here on the JDM microfiche, there are *both* part numbers listed, one for the LED wing and one for the non-led wing. (#53 vs #66)
It's $4. Just go to your local honda dealer and see if they have one in stock for you to look at/compare to the other one that you already have.
Just to wrap this up:
91505-SH3-000 is indeed the part that you want for the JDM LED rear wing if you are installing one on a USDM hatchback. The wing will work without it, but this little clip really stabilizes the center and prevents it from rattling.
happyabortion
Appearance Build Threads
05-24-2008 08:42 PM
D3U1LT
04-21-2006 06:59 PM
