MT CRX Build and Swap
#26
Re: MT CRX Build and Swap
Well she turns over.. But the main relay clicks really fast before i try to crank it... Realized I had no gas in it haha, so we will try again soon.
So my traction bar is on.. It replaces everything in the front middle... So yeah I broke out the cutoff wheel and cut the front end off haha.. Looks pretty clean to me The bar mounts where the tow hooks are and has mounts for a half size radiator, and an intercooler.
#29
I ordered a new Throttle Position Sensor. Lifetime Warranty from Dorman via Autozone. $46. 00. Seemed worth it to me. It was in stock at their warehouse, but was apparently nabbed by someone else before they got to it for me. So now one is on order for the 6th of July to get here. I will then be picking up the TPS, an alternator belt, radiator fluid, hose clamps, and anything else I can think of. Which at the moment feels like a spare main relay, some more solder, some heat shrink, because I am NOT wrapping everything else I do in tape again, and some bolts from ace to bolt my new battery tray down. Maybe I will pick up some honda white while I am at it...and the material to scrub it all down of course.
haha I will use this as my list since i can see it on my phone lol...
Paid For:
TPS - $46
Need to grab at Autozone:
1 x Alternator Belt
4 x large hose clamps
2 x small hose clamps
1 x Radiator Fluid
1 x Main Relay
1 x pack of solder -maybe
1 x 1-3 ft of heat shrink
1 x lighter or mini butane torch
3-4 x bolts to put battery tray in
1 x something to hold battery on
1 x pack of sand paper for painting
4 x cans of Honda white matching paint - passenger fender/front bumper, touch up spots...
I cant wait to see this hood by buddy picked up. I wonder when he will be able to bring it down for me. He said it looked great. No latch, so I can lose some more weight and clean my bay by getting rid of all the hood catch and release parts...
Paid For:
TPS - $46
1 x Alternator Belt
1 x Radiator Fluid
1 x Main Relay
#30
Autozone Rewards, bro. If you space your trips out by two hours, you get a point for every purchase over $20. At 5 points, you get $20 of store credit. It's a good deal.
#33
#35
Decent update....
So lots of work has been done... Um.. Yeah... Carbon Fiber hood is on... Hood pins are on and working... Passengers side is a lil tight but thats okay... It wont fly off if I go drive... Radiator hoses are on and clamped... coolant is in... needs a bit more I think for sure. Um.. Some of the gauges have been mounted. not really setup, just kinda mounted there...
So here are my problems haha.. Well fuel was um not pumping.. straight up jumped the pump and nada.. So a new pump from xenocron was sourced... 255 ltr/hr pump fuel pump. We put that on and wallah fuel in my lines and a leak at the brand new fuel filter. gah.. I forgot and couldnt find the copper washer.. Then I broke a bolt.. in the bolt...that holds the fuel line on the filter... Effff.... but i got it out and then tapped it back out. then found a copper washer for it haha.. FML.. So yeah then we try to start it and nothing...still no fuel... So now new NGK Iridiums, and new Duralast 7mm wires. Got good spark, nice and blue So yeah then still no fuel. The injectors have power, but they arent pulsing.. Wont ground out when it cranks like it is supposed to. GRRRR... So now we are trying to track that down. I think I might have messed up something in my wiring. Has to be the TDC Sensor, the Crank Sensor or the Cylinder Sensor right? haha... Well that is tomorrow... and I got to figure out a way to figure out how to get the gas tank mounted again.. bolt was rusted up and broke in half coming out..
So now pics..
I will hopefully have a video tomorrow for you all of the car running!
It does crank up when you spray carb cleaner down the intake...
So now pics..
#36
So we found a ground wire not hooked up... And I rewired the TDC, Crank Positiohn Sensor and the Cylinder Sensor... She started up and ran on her own... haha we all about crapped ourselves...
Now to tidy up and swap the knuckles back to 92 teggy ones..
oh and here you go
http://www.youtube.com/watch?v=VsttKP_Hxtg
oh and here you go
#39
Which race are you talking about?
So here is the update... well i drove it today... just around the building... it is well not running right at all. I dont know if it is the crappy gas, or what. It idles pretty good, but when you put your foot down even slightly it stutters and almost dies then will start reving slowly and erratically...
I also have a tranny leak... bad gasket or whatever between the intermediate shaft and tranny... drops a decent amount of MTF when in gear...
We hooked up a bunch of my gauges.... Tach is workin, just jumpy and I dont think very accurate. I dont like it very much. We tapped in a new thermometer for the new water temp gauge, then found the old one haha. Um the Volt meter works, the speedo doesnt.. not at all. not sure how to make it work either... i have the input line running straight from the tranny.. it is electric, and nothing... Fuel gauges is not very good, moves all over the place depending on who know what. we will see if I can iron that one out..
So yeah I will hopefully be fixing those things and swapping my knuckles back over to the DA ones I now have Stay tuned!
#40
#44
great build, looking to start my build with my crx that i am hopefully getting this weekend. but great build. im going to keep a eye on this thread till that thing is done. Gl
#45
wicked stuff guy,i dont know what its like to build a car in a parking lot of college,but ive been in the same boat with the sky above me at all time during...hats off dude ,keep it up
#48
Thanks!
Yeah me too! I was sooo happy once it decided to idle on its own!
Thanks and will do!
***UPDATE***
Went to Pep Boys today and got a new MAP Sensor, a cigarette lighter setup, the seal between the half shaft and the tranny on the driver's side, and the Genuine Honda MTF for it! I dont smoke, it is for the GPS! No I dont want to hardwire it lol.. So tomorrow should be fun. I am gonna switch the knuckles to 92 ones, hook up my MIL correctly, change the seal and fill her back up. Then I will check the codes, replace the MAP sensor with my new one (maybe), put the license plates I just got for her on, and then work on cleaning up some wiring!!
Also got oil change stuff for my 98 wrangler, new lift struts... Wow $32 a pop! But it is worth it since I am SICK of the back window falling and hitting me in the head! I also grabbed some more clamps. I need to take pictures of the gauges working... The whole swap.. Real hood pins working in her.. Ummm... Yeah the custom cold air intake my buddies made from me, but then decided they needed to sign everything they worked on. Not very cool.. But payback is a bitch... Hhahaha.. So stay tuned for lots of pics, maybe a video or two, and yeah.... Cross you fingers that she will be running right when I fill her up with new gas... Then on Monday she will be off to get exhaust thrown on!
Also bought two 5 point RCI racing harness' for when the cage goes in.. I dont want to die! And black housing headlights fogs and corners!
#50
I found out what I am going to do for exhaust....But not telling yet aha... I bet I am the first though...
Pics that are new your enjoyment!
