Hello my name is akeem i own a 89 crx si with a high comp z6
Old 05-16-2018, 03:01 PM
Akeem Willis's Avatar
Default Hello my name is akeem i own a 89 crx si with a high comp z6
Old 05-16-2018, 05:22 PM
Default Re: Hello my name is akeem i own a 89 crx si with a high comp z6
!!! Need help car start but only run for like ten mins then deads out i i placed fuel pump , fuel filter and i try different dizzy everything
Old 05-18-2018, 08:26 AM
Keyboard Humorist
4drEF's Avatar
When it deads out, does it starts right back up?
Do you get a Check Engine Light when it deads?
Have you checked for codes?
If it does not starts right back up when it deads, do a check for spark and fuel.
my first guess is that your main relay is starting to fail.
Old 05-19-2018, 08:29 AM
Thanks bro for the reply and can't really get codes for us resaon dash not working car run fine for three days after the rebuild and drive it to work and in left me there so i Chang the fuel pump and now that wat it do don't know if it's cause i have p29 piston and the compression change but i dont know i try everything from my buddy dizzy too his pressure regulator his ecu but i also was thinking of the defualted fuel pump cause is one of them eBay high flow ones for like 45 bucks
Old 08-02-2018, 12:38 PM
linkdeezie's Avatar
Icon6 Re: Hello my name is akeem i own a 89 crx si with a high comp z6
LOL - I couldn't resist...my fav movie of all time
dylaxiin
05-09-2011 07:28 PM
caliREDsuns
11
04-22-2011 06:30 AM
iNDyCRX
04-24-2008 12:54 PM
HutchCRXSi
10
09-12-2007 10:42 AM
jdm_eg
21
09-07-2004 06:49 AM
Quick Reply: Hello my name is akeem i own a 89 crx si with a high comp z6
