I have a B16 block, ls motor, b16 head with type r internals, what should I do?
A few months ago i didnt have **** but my 91 hatch. Now i have a b16 motor with type r cams, valve springs and pretty much everything in the type r head. I also have a complete ls motor and a b20 block. I am looking for ideas and suggestions on what to go with. I am thinking of doing a b16 head on the b20 block. Please give a detailed opinion, and or seggestions. Thanx
Re: I have a B16 block, ls motor, b16 head with type r internals, what should I do? (crxrider07)
do the b16 head on the b20 block and just put jdm itr pistons in it and build the head. best all motor set up ever. if boost stick with the b16 and a 57 trim and arp head studs and push 12psi plus everyday.
if you have all the stuff from the type r head get a local machinist to port b16 head to typr r specs or do it better and go a lil bit more w/ the port job
then rebuild the head do a b20/vtec and slap the engine in w/ an ls tranny (lsd)
and go have some fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beana »</TD></TR><TR><TD CLASS="quote">if you have all the stuff from the type r head get a local machinist to port b16 head to typr r specs or do it better and go a lil bit more w/ the port job
and go have some fun </TD></TR></TABLE>
naw go with b16 tranny shorter ratio
Crazy Honda Guy
Re: I have a B16 block, ls motor, b16 head with type r internals, what should I do? (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 »</TD></TR><TR><TD CLASS="quote">do the b16 head on the b20 block and just put jdm itr pistons in it and build the head. best all motor set up ever. </TD></TR></TABLE>
WTF are you talking about?
A B20 block uses 84mm pistons, B16A/B, B18A/B , B18C engines all use 81 mm pistons
Don't spread missinformation
Re: (CRex_22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRex_22 »</TD></TR><TR><TD CLASS="quote">naw go with b16 tranny shorter ratio </TD></TR></TABLE>
X2 you will love it.
Re: (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad »</TD></TR><TR><TD CLASS="quote">give it to me </TD></TR></TABLE>
yeah give me the head. or trade me the b16 head with all itr stuff in it for my completely built ls head. pm me iof interested. will give all details. not trying to make it a fs/ft thread or anything. lol
Re: (crxrider07)
Rs machine 84mm itr pistons with rings 300.00 bux!!! Then put that B16 head on that B20 bottom end. I would probably use a gsr main girdle, windage tray oil pan as well just to tie everything together.
I LUV MY NINJA
08-27-2006 09:43 PM
