main relay symptoms even though I have a NEW main relay
Old 11-20-2004, 12:40 PM
red civic standard's Avatar
Default main relay symptoms even though I have a NEW main relay
Car starts fine in the morning when it is cold. I then drive the car for 15-20 minutes to really get it warmed up. Shut it down. Go to start it again and it cranks and cranks (fuel pump is not turning on), but will not start. Let it cool down for 10 minutes and then it starts again (and runs great).
I have my battery in the trunk. Does this have anything to do with it? Is there another relay that may have to be replaced?
Old 11-21-2004, 01:43 AM
Default Re: main relay symptoms even though I have a NEW main relay (red civic standard)
up
Old 11-21-2004, 07:45 AM
T-Mo's Avatar
have you checked to see if the rotor button is on tight?
Old 11-21-2004, 08:31 AM
blo2k1's Avatar
Default Re: (T-Mo)
i thought mine was the main relay also and i had a dry cell relocated also but it ended up being that i needed to switch the gauge of wire i used to relocate my battery to 4 gauge i was using 8 gauge lol...........one way to test run it to it gets hot shut it off make sure it wont start then get your friends to give you a jump if it starts then its the wires to your battery if not then its the main relay
Old 11-21-2004, 08:39 AM
SlowHatchGrL's Avatar
Are you still DPFI?? Cuz I used to have that problem in my DX. I checked the injectors and wiring and everything was fine. It ended up being something in the ECU. That's why I switched to MPFI!!!!
Old 11-21-2004, 08:40 AM
Default Re: main relay symptoms even though I have a NEW main relay (SlowHatchGrL)
Also, is it throwing any codes? Mine would throw a code 16 (Fuel Injector) all the time.
Old 11-21-2004, 09:50 AM
The motor is MPFI and I am throwing no codes. I am currently running 4 gauge to the battery. I might have to upgrade the power wire that goes to the ecu as I am using something like a 12 gauge for that currently.
Old 11-21-2004, 11:24 AM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowHatchGrL &raquo;</TD></TR><TR><TD CLASS="quote">Also, is it throwing any codes? Mine would throw a code 16 (Fuel Injector) all the time. </TD></TR></TABLE>
that is def a main relay symptom since it powers the injectors as well.
Old 11-21-2004, 02:38 PM
Default Re: main relay symptoms even though I have a NEW main relay (Jared)
Ok, yeah sounds like a main relay.
Old 11-21-2004, 02:44 PM
rtwef9's Avatar
check the ignition coil!!
batvrdy
10-10-2018 12:50 PM
DirtyDA9
01-27-2012 11:38 AM
spencerxfr3sh
02-23-2009 05:42 PM
shreddinryguy
06-26-2005 02:03 PM
triple_s1x
02-27-2005 11:10 AM
Quick Reply: main relay symptoms even though I have a NEW main relay
