My cars going threw alternators...
Re: My cars going threw alternators... (.hatebreed)
What is saying it's bad? Did you have it bench tested or are you just going on battery consumption or something?
I don't know much about alternators, but I did just have to replace the one in my CRX a couple weeks ago. It didn't look very old at all. I was a little concerned that I could just break another one, but I guess time will tell. One thing I did learn in going through that process is that the ECU actually controls the voltage output of the alternator, so it can in essence choke it. May not be news to you, but I was kinda surprised.
i think you need to elaborate a little. your post is pretty vague. how was it determined your alternator is bad. what was the original symptoms and what have you done to remedy the problem.
Re: My cars going threw alternators... (FlyZlow)
i dont think the ecu controls voltage, the altenator has a voltage regulator and that is usually what goes bad in honda altenators.
If i were you id get a new one from honda, you probably bought a vatozone rebuilt and thats probably why your eating them up
my cars gone threw 3 alternators in the last 2 weeks. one it just died and wouldnt charge. the other it was putting out 19volts this wont dosnt seem like its charging is it my car or what?
What motor? D-series or B-series?
Have you been WOT or just cruising?
Who put it on your car (i.e. is the person putting the correct tension on the belt).
where are you getting the altenators from? try getting an oem altenator! also check your fuse block to make sure you dont have any blown fuses.
if you painted the engine bay or somehting like that make sure you scrape away the paint on all your under the hood grounds.
also make sre your battery terminals arent painted either.
its also a good idea to make sure the mechanic or you is using the proper belt tension, and not just making it as tight as possible, which is what most mechanics will do.
Re: My cars going threw alternators... (doublethink)
D15b2 with dpfi conversion. Ive been doing both wot and cruising. I put it in and i leave enuff so the belt moves a little in both directions prolly a half an inch total movement. i got the alternators @ discount auto parts. My cars running off the battery when i take a terminal off the car dies. i checked my grounds they seem ok the only one thats kinda ifffy is the valve cover to rad support one. nothings really painted.
Crx came with either a Nippon-Denso or a Mitsubishi alternator, I found this when my alternator went out and the parts store gave me the wrong one. It turned off my battery light, but it wasn't charging the battery and it broke down again! Check on the old one which you have.
Re: My cars going threw alternators... (b16sellout)
The one I just broke was the Nippon-Denso. I have the mitsubishi now. We'll see if it does better.
The computer does control the charge that the alternator puts on the battery. I just went through this w/ my car. Look it up in the shop manual. The alternator does have a regulator and a rectifier, but the ECU ultimately decides what charge to put on the battery. May not be the same on his D15, but I know it is this way on the D16A6.
FYI - Like b16sellout noted, getting a "Honda" or OEM alternator means getting either the Nippon-Denso or the Mitsubishi. The Mitsubishi alternator is what I picked up from autozone for about $100 w/ a lifetime warranty.
Also, I don't think pulling the battery cable while the car is running is a good test of the alternator. The alternator gets its ground from chassis. Pulling the battery cable opens the circuit.
it was the alternators they were giving me i took one off a friends car. worked liek a champ. autozone and discount auto parts.
Location: 9/11/01 WTC Never Forget, United States Of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .hatebreed »</TD></TR><TR><TD CLASS="quote">it was the alternators they were giving me i took one off a friends car. worked liek a champ. autozone and discount auto parts.</TD></TR></TABLE>
Trust me I learned from experience do not buy Autozone altenators...I had to get one from PepBoys with lifetime warranty
Re: My cars going threw alternators... (MR.RED'89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED’89 »</TD></TR><TR><TD CLASS="quote">
Trust me I learned from experience do not buy Autozone altenators...I had to get one from PepBoys with lifetime warranty</TD></TR></TABLE>
Autozone and Pepboys parts are basically the same quality, and autozone also offers a lifetime warranty on there alternators.
wspencer5
Honda Civic (2001 - 2005)
01-03-2015 02:10 PM
hondatechuser
12-31-2004 08:02 AM
