Which distributor do I buy?
Car is an 89 SI with the stock d16a6. Distributor went bad and I'm not sure if I need to buy the td02 distributor or td01. What's the difference?
Re: Which distributor do I buy?
The TD01 is the dual point distributor - small rectangular plug, 5 pins. TD02 is the multi point distributor - larger round plug, 7 pins.
Honda distributor code list | HondaSwap The truth is out there for those that search.
Any of the parts places will sell you the right distributor if you give them the right engine info.
It's a bone stock D16A6, what upgrades would make this advisable?
A TD41U for a D15B7 would fit, since it's essentially the same head casting. The TD42U for the D16Z6 is a different bolt pattern though, in addition to the CYP being different I think? OP probably wouldn't like to find that out after purchase.
1990 CRX HF, D16Z6 Swap, OBD0 | HondaSwap
