front tranny mount, bseries swap
Old 02-16-2015, 02:12 PM
mickeywickit's Avatar
Default front tranny mount, bseries swap
did anyone else need to hack the front tranny mount off to get the bseries motor to fit? ive got alot of viberation and it drives me insane... mainly in my dashboard.. i was thikning sticking carpet padding behind it...\
Old 02-16-2015, 03:13 PM
Ef4doorwagon's Avatar
Default Re: front tranny mount, bseries swap
What mounts did you use? I used innovative cable ones and I didn't have to cut the front mount, but my headers to touch the front cross member.
Old 02-16-2015, 03:43 PM
i used hasport, the trans was hitting the mount bracket.. it wouldent fit
Old 02-17-2015, 09:40 AM
epinero's Avatar
Was the car ever in a front end collision?
Old 02-17-2015, 10:38 AM
Keyboard Humorist
4drEF's Avatar
Aftermarket crossmember with provisions for a B-series mount will correct this.
Old 02-17-2015, 11:01 AM
footwork mastery
.Grimace's Avatar
My b18c swap was hitting on the front crossmember really bad with hasport mounts. Wanted a traction bar anyways so I went for it. Innovative sells an aftermarket front corssmember (not traction bar) that will solve the problem like he said though. For the price though it's not worth it. Extra $100 gets you a traction bar
Old 02-17-2015, 11:39 AM
epinero's Avatar
I grabbed an eBay special that attaches and replaces factory tow hitch locations. Not provision for front mount though. So far has been working great, and I don't get engine movement with the Hasports.
Old 02-18-2015, 09:35 PM
If I could weld, I would cut the front lower mount *bolt in spot*and move it over to align with the holes for the front mount. Even tho 3 solid mounts is good, wouldn't hurt to have a 4th.
InTheLBC20
08-20-2008 08:27 PM
doublethink
10-06-2007 09:30 AM
ITRswapandslow
02-12-2004 01:51 PM
Quick Reply: front tranny mount, bseries swap
