LED taillights
Old 02-01-2011, 11:44 AM
VolRex's Avatar
Default LED taillights
I saw a 92 hatch with LED taillights that looked stock, they were behind red plastic. I've been looking for a write up on how to do that to my 90 dx. The only thing I saw was for that same model and the person said it was impossible, I saw it the other day so clearly it isn't. Can anyone send me in the right direction?
Old 02-01-2011, 01:01 PM
4dred6's Avatar
Default Re: LED taillights
this might help you
Originally Posted by Hadtstec
Am in the process of making a new set, but these where my old ones:
Right then Chaps, this is really very easy. All you have to do is get a great big Hammer, then….
1. Prepare the cluster by cutting away the plastic
2. Choose a design for your lights
Make yourself a design from a 9 x 37 grid.
3. Measure the hole you made and cut a Circuit board to fit.
These images are of the shapes I used for the indicators.
4. Draw your design onto your circuit board.
Drawing the design on makes it easier to put the LEDs in later, because you don't have to recount the holes. It also allows you to double check exactly how many LEDs you need.
5. Once you know how many LEDs you need use this website http://led.linear1.org/led.wiz to determine your design.
It's a great website that clearly shows you how many LEDs you have to solder in serial and how many resistors you need. It also tells you what strength resistors you need.
The picture below is an example I used for the Break Light.
6. Now mount your LEDs onto the circuit board.
- LEDs are directional. Look at the Head of the LED. Inside the LED, the shorter part is the positive side.
- I cut the pins short, put the LEDs through the circuit board holes and then bend the pins down to keep them in place. This makes it easily to solder them together.
- At the end of a row of LEDs you need to solder in the resistor to the negate end. I chose to thread the resistor through the Circuit board.
The resistors get EXTREMELY hot when you solder them on.
7. Connect all your lots of serial LEDs in parallel.
- Solder Red cables to the positive ends of the LED strings and Black to the negative end and then solder all same colored ends together.
8. Connect the Voltage Regulators
This is the circuit diagram I made
9. Cut the connector from the bulb sockets and connect it to the Voltage regulators.
Another picture to follow
10. Solder the Ground wire from the Voltage Regulator to a ground point.
I have chosen to solder it to the screw mount which firmly sits on the car.
Picture to follow soon.
11. Glue the circuit board into place
- I used a hot glue gun, so I can remove the circuit board again if I have to.
Now that you have spent hours slaving on your kitchen desk, stand back and look at your results.
Here are some pictures of the cluster on my car in comparison to the standard light
Tips I picked up along the way / Questions
- Should I convert the indicators aswell?
In my opinion: No.
If you have decided to convert the Indicators aswell, then you need to change the flasher relay under your steering wheel.
- What strength LEDs should I buy?
I choose 5000mcd for the rear light, 8000mcd for the break light. For the Indicators I used 4500mcd LEDs, which I would now say are not strong enough.
- Do I need to use Voltage regulators?
No, but if you don’t then your car could blow LEDs when the voltage is higher when your battery is being charged.
- Can I use any rear cluster?
Yes, but by Law you have to have a red rear deflector, you can buy these as stick on strips.
- What is the minimum number of LEDs I need to use for each circuit?
Personally I would say 30 is minimum.
Old 02-01-2011, 01:19 PM
nineohnine's Avatar
hmm i was actualy thinking about try that exact same thing on some old cracked and buste light that i have... thanks for the info will help alot when i got to do this
Old 02-01-2011, 01:24 PM
4dred6's Avatar
Old 02-01-2011, 08:10 PM
VolRex's Avatar
Thanks brother. That's exactly what I wanted. I'll get on it, looks like a good mod.
Old 02-01-2011, 09:00 PM
homebuilt503's Avatar
Very cool. Cant tell if i like it or not though haha
Old 02-01-2011, 11:59 PM
fatCRXguy's Avatar
Thats awesome. but it looks like a lot of work
Old 02-02-2011, 06:44 AM
Jaime 91SiB18's Avatar
Good stuff!
Old 02-06-2011, 06:25 AM
VolRex's Avatar
Anyone know how to do the scrolling turn signals like the new mustangs have?
Old 02-06-2011, 06:30 AM
KINGVEM^^ED6's Avatar
thats a good one^ pm clipsed im sure he could help
Old 02-11-2011, 12:39 PM
harrisonj's Avatar
Great post Thank you. I've been looking for a while and was thinking I was just going to have to figure it out for myself. You have saved me from a potential wast thank you.
Old 05-19-2013, 08:02 AM
Vagitarian's Avatar
This post is amazing, but theres no way after seeing all that wiring at the end that I could handle that.
If you were to do JUST the red area in the center and not the indicator part, would it make it alot easier with the wiring?
Keep in mind oem crx lights here in the USA have that bulb on the very end of the tail lights were as the OP's tail lights were the amber wrap around style, would that make things complicated leaving that outside bulb just a bulb?
Old 01-31-2017, 05:10 PM
yan01232's Avatar
Wow great write up
Old 07-26-2017, 09:27 AM
Snakeeye83's Avatar
Or try this..
As before..get some cheapo Sonar lights
Clean the middle plastic
Weld flat plastic back-support..
Stick your favourite COB lights / colors
Some wiring/soldering skills needed
Old 07-29-2017, 09:05 AM
welfarepc's Avatar
Would love to see those in the car, would look very nice on a race car type setup with a chopped out rear bumper.
Old 06-05-2018, 08:07 AM
Snakeeye83's Avatar
For those guys that asked for scrolling (sequential) turn signals...here are the youtube links..
Now if it is not allowed to post foreign site links PLEASE admins you're free to download and embed the vids..Enjoy
Darkness
Daylight
Front
Old 06-08-2018, 07:28 AM
kraquepype's Avatar
Pretty neat, are those all custom? Its hard to find taillights for our cars that I like.
Old 06-08-2018, 12:56 PM
Creator's Avatar
Nice work Snakeeye83! Thanks for coming back a year later & posting!
Old 06-09-2018, 10:47 AM
Snakeeye83's Avatar
Yes..it's not easy to come up with a project every 6 months..
And yes they are completely custom.even had to clean out the internals of those aftermarket tail-lights..the ones with three round sections
Lights consist of COB lights and Sequential DRL's that can ease things out for personal preference
fminusmic
05-03-2018 06:31 AM
Ilovemyef9
10
01-16-2011 01:54 PM
jose_germanDC4
12-21-2010 09:07 PM
SpoonSleeper
10-05-2003 07:47 AM
Fuster_Cluck
12
11-29-2002 01:44 PM
Quick Reply: LED taillights
