L3 transmission problem (91 honda Civic) Main shaft bearing problem?
Old 10-01-2008, 04:06 PM
kdsmonitor's Avatar
Default L3 transmission problem (91 honda Civic) Main shaft bearing problem?
My transmission is making a loud whining/grinding noise when accelerating and under load. Does this sound like the main shaft bearing going bad? If it is, I plan on changing it myself. Is there a gasket between the clutch housing and the main housing? I do not see one listed in the parts available at http://www.hondaautomotiveparts.com/. I plan on buying the bearings from them. For the cost, I will probably buy all of the bearings for the main shaft and countershafts. Is there anything else I should buy?
Modified by kdsmonitor at 5:52 PM 10/1/2008
Old 10-01-2008, 05:17 PM
Tyson's Avatar
Default Re: L3 transmission problem (91 honda Civic) Main shaft bearing problem? (kdsmonitor)
i thought i had a mainshaft bearing going too. it was a grumbling noise you could feel at around 30-40mph if i remember correctly.
yes, there is a seal on the other side of the bearing. i ordered this.
1 91002-PS0-003 BEARING (26X58X15) $20.02
1 91216-PL3-005 OIL SEAL (26X42X7) $5.55
turned out to be one of the big differential bearings totally gone.
i replaced the diff with another diff with a good bearing. replaced the input shaft bearing and two axle seals and all is good.
Old 10-01-2008, 05:27 PM
kdsmonitor's Avatar
My noise is consitant through all gears , all the time unless the clutch is pushed in. The clutch, pressure plate, throwout bearing, flywheel, and pilot bearing were replaced this last weekend. The noise was present before the clutch replacement. I was hoping the clutch would have fixed it..
Old 10-01-2008, 05:30 PM
Tyson's Avatar
Default Re: L3 transmission problem (kdsmonitor)
sorry man, thats a bearing issue.
at least now youll be better at dropping the tranny and putting it back in
Old 10-02-2008, 06:32 AM
rustbucketrex's Avatar
Default Re: L3 transmission problem (Tyson)
No gasket, just Honda Bond to seal it.
Old 10-02-2008, 06:56 AM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kdsmonitor &raquo;</TD></TR><TR><TD CLASS="quote">My noise is consitant through all gears , all the time unless the clutch is pushed in. The clutch, pressure plate, throwout bearing, flywheel, and pilot bearing were replaced this last weekend. The noise was present before the clutch replacement. I was hoping the clutch would have fixed it..</TD></TR></TABLE>
i'd bet anything there isn't enough fluid in the tranny
Old 10-02-2008, 10:27 AM
Tyson's Avatar
Default Re: L3 transmission problem (rustbucketrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rustbucketrex &raquo;</TD></TR><TR><TD CLASS="quote">No gasket, just Honda Bond to seal it.</TD></TR></TABLE>
doh, thats what he meant...
yeah hondabond. accept no substitute.
TravisBiggie
Honda Civic (2001 - 2005)
11-25-2012 02:00 PM
95_Civic_4dr
Transmission & Drivetrain
01-25-2011 10:26 PM
prelude182
08-03-2009 05:53 PM
Pbanto
04-08-2009 05:07 AM
eda6
01-26-2008 03:26 PM
Quick Reply: L3 transmission problem (91 honda Civic) Main shaft bearing problem?
