k20rex's crx build
#26
Re: k20rex's crx build
the wheels sit almost true, i think that the da knuckle that i'm using is bit different curve that stock crx but guys have made it work right with camber kit,
picture with the itr knuckle on there it looks like a lowrider on hydro's with the wheels tilted out bad
#28
ben mocking up the wire tuck, i will be putting loom over the wires and using rubber garments were it passes through metal, here it is the drivers side so far, i need to order some braided loom form summit racing
#29
i took the type r valve cover off and put a stock type s cover back on then pulled the engine out to bash the cross member for clearance and drop the engine back in today, got a picture of my redneck lift while i was doing it, i pulled it from the top and put it in from the bottom, i will never try from the top again
#32
i took the linkage off right after the engine went back in and my hybrid racing shifter box will be shipped on monday it has ben on back order for a while now, also got the stock exgaust off and test fitted the header
#34
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/cluster-lets-see-them-2443255/
#35
brithday bump and small update i finally got my hybrid racing shifer box its hella bad a$$ it adjustable like 15 or so different ways well worth the money if your go k20 swap you need this but but i only got two bolts to line up, i think i will need to drill out two more holes eazy fix
#36
for my brithday today the lady got me a skunk 2 camber kit i'm stoked about it, this is my frist aftermarket supention part hopefully lot mort to come
#39
wow, I'm surprised I haven't seen your build thread yet, lol. Looks really good so far. If you want some info on the brake upgrade I'm doing, let me know and i'll get you the details on what you'll need.
#41
valve cover on k20 is right where the brake propostion valve was so kinda have to tuck or bend out of the way, tuck is cleaner
i would like to look into the brake swap and price it out any info would be cool i already have 16in wheels so im covered there
#46
my dash is out of my car right now but here is a few pictures, the cluster fits good in the crx dash but a gap on bottom edge and around the bottom corner a little
#47
i have finally got both floor mats painted up, but the passenger side did not turn out very good, something went wrong with the white paint, cuz its all over the black now so i will need to re-spray black again
#50
i have ben thinking about redoing my quarter panels, just because a little worried i may not have cut enough out, from the looks of the pictures what do you guys think? should i redo them or wait and see what happens? i dont plan on re-stripping it for paint for about a year or so
i was wondering if anyone has used these ebay quarters before and how they turned out?
http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories
