Just in . . . Syncromesh FM
Well, I just dumped some GM Syncro Friction Modified yesterday, and I have to say, I want to have love relations with it. Before I put it in, I was starting to have problems putting it into gear, first, of course third gear, then second, fourth AND fifth. Well, I hear this stuff needs some 500 - 1000 miles to break in, but I drove it less than a mile and the gears started sliding into place.
I haven't tried it on any high rev applications like sitting at red lights and pretending I'm fast, but I'll let ya'll know how it turns out. So far so good. https://honda-tech.com/forums/images/smilies/emthup.gif *In my crx, 91 d16a6 |
Re: Just in . . . Syncromesh FM (didyouhearthat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by didyouhearthat »</TD></TR><TR><TD CLASS="quote">I want to have love relations with it. </TD></TR></TABLE>
I don't think that would be a healthy decision. Other than that disturbing image, I may have to give this stuff a try. |
Re: Just in . . . Syncromesh FM (Home Skillet)
ya me too, every1 seems to love this stuff.. DAMN GM.
did you just dump a bit in or did do a whole transmission fluid change?
Re: Just in . . . Syncromesh FM (tony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony »</TD></TR><TR><TD CLASS="quote">did you just dump a bit in or did do a whole transmission fluid change?</TD></TR></TABLE>
I did the whole change. Drained the old, put in almost two quarts of the new. |
Yup, it worked wonders on my car.
Re: (Waachback)
i'm going to use some whenever i do the ls 5th swap over spring break
i hope it lives up to its name |
Anyone eles try Lucas? I thought it helped tremendously...
Re: (Smokinsax)
i'm going to walk into chevrolet and get this stuff and tell them i'm going to put it in a HONDA!!!! !!! and run away laughing..
Re: (XtraFastCRX)
I'm gonna have to try it to. I HATE my tranny
all my buddies rave about the stuff, i have never got around to buying it though.....i will someday.
Re: (redzcstandardhatch)
I need to buy some of this crap .. how much did it cost ya?
Re: (BioXide02)
Find a friend that works for GM, or it's probably going to cost you $10+. I saw it online for like $6-7 ea. when you buy six.
check out BG Syncro Shift II® It's been tested to perform many times better than the GM syncromesh. Modified by d357r0y at 12:42 PM 3/5/2004 |
Just wait two more days or so. It only gets better https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Just in . . . Syncromesh FM (Targa250R)
how much do u need of this stuff?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony »</TD></TR><TR><TD CLASS="quote">how much do u need of this stuff?</TD></TR></TABLE>
I believe 2 bottles for D-series, and 3 bottles for B-series. |
I love that stuff.... Didnt make an immeadiant difference.... After about 500 miles and one day of hard driving..... it was soooo smooth....... I love it and I dont even have the FM...
Blaze |
Re: Just in . . . Syncromesh FM (Blaze45)
i put some of the pennzoil synchromesh without FM from my work and it got rid of all my grinds. best fluid ive ever used, even better than redline MTL. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Just in . . . Syncromesh FM (kwik_B16)
ok now im confused, i thought that the synchromesh stuff was a pastey goop kinda of thing, like toothpaste consistency that you would use in conjunction with honda MTF. or does it replace the MTF completely?
Re: Just in . . . Syncromesh FM (GSRCRXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">ok now im confused, i thought that the synchromesh stuff was a pastey goop kinda of thing, like toothpaste consistency that you would use in conjunction with honda MTF. or does it replace the MTF completely?</TD></TR></TABLE>
no its just tranny fluid. you remove all the old tranny fluid, and put the GM synchromesh friction modified tranny fluid in. yeah, i can't wait to put it in my tranny. thats when i get the car started. hopefully i will notice no grinds and i can just think that i got the most perfect tranny ever. https://honda-tech.com/forums/images/smilies/emthup.gif |
No, like he said, it's tranny fluid. You replace your Honda MTF with the Synchromesh. Synchromesh actually has a thinner consistency than most other tranny fluids I have seen. |
Gm syncormesh works great. I used it in my tranny also. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
yes! the pennzoil stuff, can find it at autozone, its the same part number as the stuff from the gm dealers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik_B16 »</TD></TR><TR><TD CLASS="quote">i put some of the pennzoil synchromesh without FM from my work and it got rid of all my grinds. best fluid ive ever used, even better than redline MTL. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> says who?? gm syncromesh is the best i've ever used, and I've only seen people switch from bg to gm syncromesh... but that link is for bg 2, dunno if thats any different <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y »</TD></TR><TR><TD CLASS="quote"> check out BG Syncro Shift II® It's been tested to perform many times better than the GM syncromesh. Modified by d357r0y at 12:42 PM 3/5/2004</TD></TR></TABLE> |
Syncromesh Friction Modified works:
Put it in my d16-Y8 cured that nasty reverse crunching grind, no need to put it in 1st gear first anymore before you reverse it. Shifting feels a bit slicker all over too. |
