Just another "help me, my car wont start" thread. All comments are appreciated. Thanks
Old 06-24-2005, 09:03 AM
Jwbetley's Avatar
Default Just another "help me, my car wont start" thread. All comments are appreciated. Thanks
So. I just bought a 89 civic wagon. The thing is rusted to hell with 189,000 miles on it lookin' ghetto as hell; I F#$% love it. I got it for $200. The woman that sold it to me told me it needed a new clutch. I drove it and immediately knew it was just a loose clutch cable, but i didn't tell her that, thus me getting a very cheap car.
The problem: The car only starts sometimes. When it does run, itl keep running. When i stop it after ten minuits, it will NOT start. It I run it for 40 mins, it starts up fine. When it doesn't start, a little gas or starter fluid in the throttle body does the trick. What could it be? I have plenty of spark, good compression, and timing is on. Now, i am pretty sure it is the fuel. I own a 95 civic so Im not too experienced with this fuel injection system. I dont know where the fuel rail is and the fuel pump isn't in the gas tank. Lookin' for someone that knows these cars well.
thanks
Old 06-24-2005, 09:11 AM
91civicEX's Avatar
Default Re: Just another "help me, my car wont start" thread. All comments are appreciated. Thanks (Jwbetl
Main relay
everything is more or less like your 95
the main relay is located in the drivers side left kick panel by the hood latch cable. you should hear it click everytime you turn the key to RUN. if you dont its bad. when the car wont start keep cranking till it throws a code. then pull up on the passenger side carpet and youll see a little window. itll be blinking. count the blinks. if its blinks 16 times then im right. cuz thats a fuel system code.
Old 06-25-2005, 06:56 AM
Jwbetley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">Main relay
the main relay is located in the drivers side left kick panel by the hood latch cable. you should hear it click everytime you turn the key to RUN. if you dont its bad. when the car wont start keep cranking till it throws a code. then pull up on the passenger side carpet and youll see a little window. itll be blinking. count the blinks. if its blinks 16 times then im right. cuz thats a fuel system code.</TD></TR></TABLE>
You know your ****... 16 blinks. Im off to buy a new relay and try my luck. Ill let you know how it works. Thanks so far.
Old 06-25-2005, 08:40 AM
mr. carpenter's Avatar
you can also resolder the old one. my friend did it and has been running it like that for two years.
HondaJDMLife
08-24-2014 11:35 AM
91_shoebox_Si
03-20-2011 07:53 PM
Dnycest
04-07-2007 10:31 AM
BlueLude84
01-13-2007 10:11 PM
DohcRex
01-27-2004 03:34 PM
Quick Reply: Just another "help me, my car wont start" thread. All comments are appreciated. Thanks
